What's the heaviest tag trailer you have pulled with a 3/4 ton?
   / What's the heaviest tag trailer you have pulled with a 3/4 ton? #1
bdog
Elite Member
Texas
John Deere 6130M
I am a big fan of goosenecks for heavy loads. In fact I got rid of nearly all my tag trailers in favor of goosenecks. I have towed Over 10k pounds many times on a tag trailer behind a 3/4 ton and it worked but I didn't like it near as much as a gooseneck.
Anyway I now have a tag equipment trailer rated for 21k with a pintle hitch. I primarily got it to pull behind either of my dump trucks but thought has crossed my mind to pull it behind my pickup in a pinch. Certainly not a regular thing and not at max capacity. The trailer probably weighs 6k empty and I would haul either my skid steer or backhoe which are around 8,500lb each so the gross would be 14-15k.
I see they make 20k rated pintle hooks for 2" receivers and the receiver on my truck is custom built into my flatbed and is good for that amount of more.
   / What's the heaviest tag trailer you have pulled with a 3/4 ton? #2
How close is the drive axle to the bumper.
   / What's the heaviest tag trailer you have pulled with a 3/4 ton? #3
25,000# behind my SRW F350. Pulled it about 60 miles once a year for the last 10 years now.
Chris
Is that legal?
I have been checked by the DOT numerous times and I have never seen them question or ask about manufacturers gross weight ratings. I know I have been over when checked and no ticket. All they seem to care about is that you are not over axle weights, tire weights, or registered weight.
If you had a trailer that was rated and registered for that much weight and it didn't put your pickup axle or tires over weight I don't think they would give you a ticket.
   / What's the heaviest tag trailer you have pulled with a 3/4 ton? #7
My Nissan has a 3/4-ton rating (remember the old Toyota and Nissan dually trucks?).
The heaviest I've pulled was about 8,500-lbs here:
No, I never went very fast. I think I got up to a top speed of about 35 MPH.
My truck is able to pull the Kubota much easier (roughly 4,000-lbs less) and feels safe at 50 MPH.
It's no Super Duty truck, but it also did not cost me a Super Duty bank loan.
   / What's the heaviest tag trailer you have pulled with a 3/4 ton? #8
A GMC 2500HD Diesel
Econoline Backhoe Pro 12 Ton 23ft trailer. (Trailer 5000#)
Case 580 Backhoe with two rear buckets. (Approx 15,000#)
Mostly flat road.
Noticed I was towing heavy but otherwise, no problem.
   / What's the heaviest tag trailer you have pulled with a 3/4 ton? #9
14,000# no problem, tows great and stops well.
   / What's the heaviest tag trailer you have pulled with a 3/4 ton? #10
15-16K depending on what is in the boat. twice a year
CFG Industry QH12R Mini Excavator (A57149)
CFG Industry QH12R...
LandPride AFM4216 (A57149)
LandPride AFM4216...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
2011 ORTEQ TANK MANIFOLD (A58216)
2011 ORTEQ TANK...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
