What's the heaviest tag trailer you have pulled with a 3/4 ton?
   / What's the heaviest tag trailer you have pulled with a 3/4 ton? #1
bdog
Elite Member
Texas
John Deere 6130M
I am a big fan of goosenecks for heavy loads. In fact I got rid of nearly all my tag trailers in favor of goosenecks. I have towed Over 10k pounds many times on a tag trailer behind a 3/4 ton and it worked but I didn't like it near as much as a gooseneck.
Anyway I now have a tag equipment trailer rated for 21k with a pintle hitch. I primarily got it to pull behind either of my dump trucks but thought has crossed my mind to pull it behind my pickup in a pinch. Certainly not a regular thing and not at max capacity. The trailer probably weighs 6k empty and I would haul either my skid steer or backhoe which are around 8,500lb each so the gross would be 14-15k.
I see they make 20k rated pintle hooks for 2" receivers and the receiver on my truck is custom built into my flatbed and is good for that amount of more.
   / What's the heaviest tag trailer you have pulled with a 3/4 ton? #2
How close is the drive axle to the bumper.
   / What's the heaviest tag trailer you have pulled with a 3/4 ton? #3
25,000# behind my SRW F350. Pulled it about 60 miles once a year for the last 10 years now.
Chris
Is that legal?
I have been checked by the DOT numerous times and I have never seen them question or ask about manufacturers gross weight ratings. I know I have been over when checked and no ticket. All they seem to care about is that you are not over axle weights, tire weights, or registered weight.
If you had a trailer that was rated and registered for that much weight and it didn't put your pickup axle or tires over weight I don't think they would give you a ticket.
   / What's the heaviest tag trailer you have pulled with a 3/4 ton? #7
My Nissan has a 3/4-ton rating (remember the old Toyota and Nissan dually trucks?).
The heaviest I've pulled was about 8,500-lbs here:
No, I never went very fast. I think I got up to a top speed of about 35 MPH.
My truck is able to pull the Kubota much easier (roughly 4,000-lbs less) and feels safe at 50 MPH.
It's no Super Duty truck, but it also did not cost me a Super Duty bank loan.
   / What's the heaviest tag trailer you have pulled with a 3/4 ton? #8
A GMC 2500HD Diesel
Econoline Backhoe Pro 12 Ton 23ft trailer. (Trailer 5000#)
Case 580 Backhoe with two rear buckets. (Approx 15,000#)
Mostly flat road.
Noticed I was towing heavy but otherwise, no problem.
   / What's the heaviest tag trailer you have pulled with a 3/4 ton? #9
14,000# no problem, tows great and stops well.
   / What's the heaviest tag trailer you have pulled with a 3/4 ton? #10
15-16K depending on what is in the boat. twice a year
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56438)
2016 KBH...
Pickup Truck (A59230)
Lone Star dump trailer (A55973)
Lone Star dump...
208315 (A58376)
208315 (A58376)
FUEL CELL (A58214)
FUEL CELL (A58214)
