Small Dozer under 10,000 lbs ... do they exist?
   / Small Dozer under 10,000 lbs ... do they exist? #11
can't spell it but a good operator on a 150 tak skid can do as much as one on D3 dozer
That is not going to happen. A d3 weighs close to double what that skid steer weighs. Doing any serious earth moving a d3 will eat that skid steers lunch.
   / Small Dozer under 10,000 lbs ... do they exist? #12
Yup, the guy on the D-3 would have to be sound asleep! lol
I have a Case 450,
I haul it on my trailer rated for 12K...and no the trailer is not maxed out!
SR
   / Small Dozer under 10,000 lbs ... do they exist? #14
Can anyone point out a few machines that I could look at? I am considering picking up a small dozer as my business expands. But I would like something that I could trailer around easily. I am rated to pull around 18,000 pounds but would like to keep the machine under 10K on a 14K trailer (trailer would weigh around 3K).
Or... Would a tracked skid steer with a dozer blade be okay for site grading? I'm worried that the skid steer would be prone to the same issues that a tractor has: due to where the loader connects, when the blade would start digging it would cause the machine to dip and dig in ... Whereas the dozers short arms would keep the machine level and be more efficient.
Thoughts and/or recommendations?
A much cheaper alternative would be a to use your box blade and add a mast, laser receiver indicate system and a good slope laser. There are some pretty good receivers with a remote for the cab so you don't have to turn around to see what is happening. For small sites a $2000 laser and a $1000 receiver with remote display would help a lot with grading.
I grade some larger fields and use a Topcon RL200 2/s laser with a range of 1800' radius and use the Topcon LSB110 receivers which work with automatic machine control. This stuff is costly but it does help with grading accuracy and can be used on larger tractors if you upgrade later.
Working in town on lots that need finish grading primarily your existing box blade should work very well. You just need to add a pipe mast and 30 lbs of electronics.
   / Small Dozer under 10,000 lbs ... do they exist? #15
The kind that Steve linked tie into the hydraulics and level the cutting edge on the fly.
Notice that it is using a Spectra laser and the HL700 receiver. :)
For machine control you want the spectra CR600 receiver.
Anyway, this is the set-up I want to buy for my rear box blade.
I do lots of grading with the boxblade, and it does work well for the price. But it's not always the right tool, especially when adjusting side slopes. I'd try a 4-in-1 blade on my tractor, but I just don't think I could get enough traction with a CUT like mine.
   / Small Dozer under 10,000 lbs ... do they exist? #17
   / Small Dozer under 10,000 lbs ... do they exist? #19
The Komatsu dozers, specifically the D20, 21 series weigh in under 10,000 lbs. These are good little dozers that will really put out the work. Do a search on the D20p6 or D21-A for a sampling, parts are readily available and they are fairly easy to work on.
   / Small Dozer under 10,000 lbs ... do they exist? #20
If you have enough work on side slopes a small dozer would be a good choice. I had a Deere 450 years ago and pulled it with a dump truck. One thing I learned about this business is you can only drive one piece at a time, the more you have the more is sitting. You can hire employees if you can find ones that are worth it. Good luck with the decisions.
10 ft Shipping Container (A55973)
10 ft Shipping...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2019 Ford F-150...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2011 Ford F-150 Ext. Cab Pickup Truck (A55973)
2011 Ford F-150...
2018 CATERPILLAR 289D SKID STEER (A52709)
2018 CATERPILLAR...
