Small Dozer under 10,000 lbs ... do they exist?
   / Small Dozer under 10,000 lbs ... do they exist? #21
I'm pretty sure my Case 450 is right about 10k lbs, maybe a little under. My trailer can have about 18k on the deck and the dozer doesn't make the springs even budge. I used it for pretty much everything when it came to leveling or grading. But since getting my grading scrapper I now use the 450 for the rough work and the tractor to finish things off. Often times there will be humps and dips in the land that I would like to smooth. With the dozer I can take a 2' high 30' long hump and cut it down in minutes. Then when things are close the tractor can remove the track marks in the land, the rippers do a nice job at gathering the roots, and it smooths the ground without compacting it too much making it much easier to get grass growing. $15k isn't going to get you much of a dozer around here. I think you could find one and the good thing about the older Case dozers is there are lots of aftermarket parts around. The 6-way blade just can't be matched, would never get a dozer without one.
The biggest problem with buying a dozer is there is a lot to look out for. It's not just the chain and rollers. The trunnions for the blade should be checked. The front wheels have bearings in them that can go bad. Unlike a car you just can jack it up and shake the wheel to see if it wobbles. Then there's the rear drive sprockets, there are bearings for them as well. The seals take a lot of abuse and can fail. Then there's the fact that dozers are very rough. All that vibration and shaking tends to loosen up bolts. If the previous owner didn't keep everything tight holes will get oblonged (not sure if that's a real word). That makes keeping them tight in the future very hard. I have about a half dozen grouser pads that just can't stay tightened because a previous owner never checked them.
If you don't know much about dozers and you don't have someone to help you then here are a few tips. Take a look at the tracks. They have adjusters, how far are they adjusted? What shape is the rear sprocket in? If it looks unusually great shape the seller may have replaced just it and not the chain. Simply using the front blade you should be able to lift the front of the dozer off of the ground. If the chain is slightly loose you should be able to try and spin the lower rollers to check the bearings and to look for excessive wear. On my Case it uses grease and a grease gun to tighten the tracks. The zerk fitting can be easily removed allowing the front idler to slide backwards to loosen the chain up to check it. Other things to look for would be the blade and all of it's pins to see how much wear they have. A worn blade will make it very hard to be precise. If it's got mud on it have the seller wash it all off. Dozers rarely get a good washing and mud will hide damage. It will also build up between the oil pan and skid plate. That could cause the oil pan to rust out. Finally check the gauges. They have good information. On my Case the charge pump will build up about 175 psi of pressure that feeds the torque converter. A trick if the charge pump is starting to go is to park the dozer on a slope with the front lower than the back. This will help get fluid to a pump that's not able to create enough of a suction because it's worn.
Over all a small (Case 450 size) dozer is a very nice tool. I'll do things a tractor couldn't even dream of. But the steel tracks do wear and cost a lot of money to repair/ replace. I had a rear bearing go when working in some deep mud and the track fell off. I was able to drag it back to hard ground with a 3/8 chain and my backhoe. But everything with a dozer is heavy. Just like a filled tire on a tractor a dozer's track is not something you can easily manhandle. Plus there's lots of places for fingers to get pinched. Buy one in good shape and keep on top of it and it'll make you plenty of money.
Thanks for all the tips so far fellas. I'll keep researching and see what's around me.
   / Small Dozer under 10,000 lbs ... do they exist? #23
Eric,
The GL522 is a very nice laser and I considered it when I was shopping. The inspector that checks my work has one similar to it (can't remember the model number). I decided on the Topcon rl200 2/s because it has a higher accuracy, longer range and remote with 1000' range. I wanted my laser to be more accurate than the governments inspector. So far that has paid off as I have always passed the inspection and have been closer to grade than required. That means I can get paid.
The larger Spectra receivers are great and easy to see, one of these with a remote in the cab is a great choice. The smaller one you show has a much shorter pick up range and is not 360 degrees, so you will loose the signal in turns. Just something to consider.
About 8K give or take:
Komatsu Dozer
In my watch list already lol...
Most likely won't buy one till at least Spring ... But this gives me time to research and decide. Still not sure if this is the right piece, or if a tracked SS would be better overall due to its versatility.
   / Small Dozer under 10,000 lbs ... do they exist? #26
TSO -
Was just typing when you stole my thunder.....:laughing:
If you have a dedicated need for the dozer, you mentioned grading....a dozer is the way to go.
However, a tracked SS is also a potent machine, as you said that can give you tenfold versatility. I just picked up a 289C and the seller offered a 6-way front blade attachment.....I thought about it long and hard but already have the dozer. The 289 weighs in around 10,500 lbs!
As for dozers, my Komatsu has been a great machine and I'm assuming the smaller 20 & 21's would be equally reliable from what I've heard and read.
Another consideration is if rubber or steel tracks would work better for you.....the smaller komatsu's also offer swamp tracks if that is a consideration.
Good luck!
   / Small Dozer under 10,000 lbs ... do they exist? #27
I sometimes work in heavy clay dirt which can prove challenging to my Kubota L39. Have been thinking about a small dozer. Ran one many decades ago. Anyone have thoughts or experience with the Nortrac 35 hp diesel tracked dozer?
   / Small Dozer under 10,000 lbs ... do they exist? #28
What I know about these is parts are hard to get and it takes a long time to get them. I looked at 2 in the area where I live last spring. Each one had low hours but a steering clutch was bad on one side. The owners of them wanted them gone bad. These machines had sat and I think maybe that was the problem that caused the steering clutch to act up. The owner of the first one wanted 2500 for it and the owner of number 2 wanted 4000 for his which his was was a newer machine. Both said the engine was a strong engine with no trouble at all. The first machine ended up selling for 1500 and had I known about it sooner I would have taken a chance
   / Small Dozer under 10,000 lbs ... do they exist? #29
Have a Case 450. Good little machine. You'll be surprised at how much work it'll do. When we have to move it its moved on a 14k 16'GN. Never have weighted it.
   / Small Dozer under 10,000 lbs ... do they exist? #30
The Komatsu dozers, specifically the D20, 21 series weigh in under 10,000 lbs. These are good little dozers that will really put out the work. Do a search on the D20p6 or D21-A for a sampling, parts are readily available and they are fairly easy to work on.
^^^^ This. My first Dozer was a D21 Komatsu. You cannot compare a real dozer with a SkidSteer. A SS is a jack of all trades and does nothing well. Nor can you compare a box blade on tractor, no down pressure, a 500-1,000lb tool compared with a 10K dozer?? no way.
The only thing bad about a small dozer is it makes you want a larger dozer.
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
LOT: (2) Kimball Midwest 40-Hole Hardware Cabinets w/Contents (A59076)
LOT: (2) Kimball...
NEW Thiessen Track Closer Disk (A56435)
NEW Thiessen Track...
NEW Wolverine 36in Skid Steer Grapple Bucket (A59000)
NEW Wolverine 36in...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
