sashooter
Member
- Joined
- May 19, 2015
- Messages
- 47
- Location
- Twin Cities, MN
- Tractor
- 1953 Ford Jubilee 2020 Kioti CK 3510SE
There are 2 "wear issues" to be considered on the hub/axle fitment. 1st, the "incline" between the components can wear, in which case the metal shims could help the poor fitment. As the "incline" wears, the hub will have to go further onto the axle to be tight. Eventually, the axle shoulder will protrude from the hub and the jointure can't be tightened adequately. 2nd, the splines on the hubs, being softer, can wear on the "sides", allowing radial movement of the hub on the axle, when reversing tractor direction. In this case, the radial movement will quickly cause further wear.
For your repair it seems what you did is order new hubs and axles? With new hubs and axles you would not need the shims at all? Everything should go back as new correct?
