?? NAA Lift Arm Pivot Stud in axle housing spinning
   / ?? NAA Lift Arm Pivot Stud in axle housing spinning #71
I like it. Nice job.
   / ?? NAA Lift Arm Pivot Stud in axle housing spinning #72
The back blade comes in handy for backfilling and grading around the pole building also spreading gravel.
I know sometimes they are put back into service before they are really done but when there's work to be done these little fords got to step up to the plate and Get R Done.
Kirk
Thanks! It certainly looks better, but I'm sure, in a show, there would be many things, which would receive criticism. I guess, the biggest thing, would be the sheet metal, as it had many spider cracks, welds, dents and dings, etc.. I did quite a lot of welding to the cracks and some body work, but in some cases, it was nearly impossible to tell what needed to be done.
The back blade is probably second to the brush hog, in use.
   / ?? NAA Lift Arm Pivot Stud in axle housing spinning #75
Glad to see you getting some use out of it. Looks good. Hopefully I'll get mine out in the yard and cause some terror
2008 Chevrolet Trailblazer SUV (A51694)
2008 Chevrolet...
safety baskets (A53421)
safety baskets...
John Deere MX10 Rotary Cutter (A53117)
John Deere MX10...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A52705)
2021 HAMM HD+9I VO...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
