Kioti DK45SE HST still leaking oil
   / Kioti DK45SE HST still leaking oil #11
You're probably running in the correct RPM range, and have experience that some might not have from doing many many loads. Also, one learns from use when to let off the pedal so it won't stall.
It's not difficult to not stall once the technique is mastered; it's getting to that point that takes a while.
Perhaps you are correct.. I have been running hydro tractors for a day or two, and at least 2 dump truck loads of fill:D I do work the pedal and joystick constantly to get max bucketload on each attempt.
I think the next time I get a load or two, I am going to make some real attempts to kill the engine and see if I can do it.
When I start looking at all the flat ground I have created around here and start adding up the money for the material it took to build them, I get a sick feeling in my stomach.
   / Kioti DK45SE HST still leaking oil #12
Look up at the sky and you will feel better!:thumbsup:
Why try to stall your tractor? Just enjoy it, and don't try to do what others are attempting to avoid....
My 2.5 cents.
   / Kioti DK45SE HST still leaking oil #13
I had the same thing happen to my DK 40se. Turned out to be leaking seals on the hydraulic pump. They had to split the tractor to get to the seals that were leaking. It started as a minor leak that would only occur when using the loader. Take it to the dealer and make them fix it. Splitting the tractor can
be a pain
   / Kioti DK45SE HST still leaking oil #14
be a pain
M DK40SE had the exact same problem and solution... fixed under warranty but took 3 trips to the dealer.
UNUSED FUTURE 32" HYD TILTING BUCKET (A51248)
UNUSED FUTURE 32"...
2013 Ford F-150 4x4 Pickup Truck (A51692)
2013 Ford F-150...
2005 Honda Foreman 420 (A50123)
2005 Honda Foreman...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
