Kioti DK45SE HST still leaking oil
   / Kioti DK45SE HST still leaking oil #11
You're probably running in the correct RPM range, and have experience that some might not have from doing many many loads. Also, one learns from use when to let off the pedal so it won't stall.
It's not difficult to not stall once the technique is mastered; it's getting to that point that takes a while.
Perhaps you are correct.. I have been running hydro tractors for a day or two, and at least 2 dump truck loads of fill:D I do work the pedal and joystick constantly to get max bucketload on each attempt.
I think the next time I get a load or two, I am going to make some real attempts to kill the engine and see if I can do it.
When I start looking at all the flat ground I have created around here and start adding up the money for the material it took to build them, I get a sick feeling in my stomach.
   / Kioti DK45SE HST still leaking oil #12
Look up at the sky and you will feel better!:thumbsup:
Why try to stall your tractor? Just enjoy it, and don't try to do what others are attempting to avoid....
My 2.5 cents.
   / Kioti DK45SE HST still leaking oil #13
I had the same thing happen to my DK 40se. Turned out to be leaking seals on the hydraulic pump. They had to split the tractor to get to the seals that were leaking. It started as a minor leak that would only occur when using the loader. Take it to the dealer and make them fix it. Splitting the tractor can
be a pain
   / Kioti DK45SE HST still leaking oil #14
be a pain
M DK40SE had the exact same problem and solution... fixed under warranty but took 3 trips to the dealer.
MURRAY 22" 2N1 SELF PROPELLED PUSH LAWN MOWER (A51248)
MURRAY 22" 2N1...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
UNUSED FUTURE 14' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 14'...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A53472)
2022 Down2Earth...
