Plastic poly tanks used for fuel?
   / Plastic poly tanks used for fuel? #11
Ditto on the totes if you cannot find a used tank.
Around here, MANY people use the IBC totes. Which also makes the cost of used steel tanks near dirt cheap too. So around me, whatever you want is usually pretty cheap.
   / Plastic poly tanks used for fuel? #12
I didn't think the IBC totes were rated for fuel?
DEWFPO
   / Plastic poly tanks used for fuel? #13
DEWFPO
Probably not, thats why they are cheap. I wouldnt use them for gas, but they are commonly used to transport oils and chemicals. I dont see diesel being an issue.
I use old 5gal hydraulic oil buckets for diesel fuel all the time. I dont suppose they are rated for fuel either.
   / Plastic poly tanks used for fuel? #14
Where you at? I have about 30 fuel tanks for sale. 300 gallon steel tank, 12v pump, meter, hose, and nozzel for $500 550 gallon with the same setup is $600 1000 gallon with same setup is $875 All located in Indianapolis 3 miles off I70. Chris
What other tanks do you have? I'm looking for a 100-150 gallon tank.
I thought about one of the totes, my wife's brother farms and has about 100 setting behind their shop. He does not recommend them, says they start to breakdown and get chalky after setting in the sun for a few years. He has a fuel tank he will give me but it is a 2000 gal, just slightly bigger than needed but tempting. There is a guy selling totes for 100 bucks apiece just south of me claims his do not breakdown, maybe his is of a better grade of plastic.
   / Plastic poly tanks used for fuel? #16
I am about 400 miles from Indianapolis. Are these new? $600 for a 550 gal and pump seems like a smoking deal compared to what I am looking at. I have found one used 500 gal tank with water and oil in it (rusty inside) and they are stuck on $500 and I get keep the oil and water to dispose of.
No used. All were cleaned, painted, inspected, tested, and stored 1.5 years ago. We are going away from keeping fuel on site to just a delivery system.
Chris
   / Plastic poly tanks used for fuel? #17
Just 300 and 550 gallon ones. Sold all our 1000 gallon tanks this week.
Chris
   / Plastic poly tanks used for fuel? #18
It's a bit of a pain handling 5 gallons at a time but I use genuine Wavian mil-spec steel jerry cans. Nothing permeates out of the fuel like it does if stored in plastic and no potential moisture issues.
   / Plastic poly tanks used for fuel? #19
If the tank isn't rated for fuel use, then it's not capable of handling fuel, period, end of story.
A yellow, 5 gallon diesel jug you pay $15 for is made out the same polyethylene material [and much thicker] as a 275 gallon IBC tote.
   / Plastic poly tanks used for fuel? #20
Nice thing about the semi truck fuel tanks one could easily find at salvage yards... they are aluminum. No rusting issues. Except in rare cases, they all have drain plug in one of the ends that works great for installing a fuel filter and hose setup. Put on an elevated base, and it would do a great job as a gravity feed fuel tank. Generally, one can get them up to 150 gallons.
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
UNUSED LANDHONOR...
2018 KUBOTA SVL95-2S SKID STEER (A52705)
2018 KUBOTA...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
