Hydraulic fluid or 30 Wt oil 53 Super C
   / Hydraulic fluid or 30 Wt oil 53 Super C #11
He probably meant the rockshaft arms. If you have Fast Hitch on it, it is a two way cylinder, so one side always acts as a reservoir, and shouldn't cause an overflow.
   / Hydraulic fluid or 30 Wt oil 53 Super C #12
IMHO, there will be a small volume difference extended or not, even on DA due to rod diameter/displacement.
that's why i wouldn't fill one to the 'brim' anyway. :) takes very little oil to stroke those cylinders.
   / Hydraulic fluid or 30 Wt oil 53 Super C #13
True. I usually try to fill it far enough I can touch the oil, measuring with the first joint of my pinky finger, down inside the reservoir. It allows for a bit of expansion also, after the oil warms up.
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
JOHN DEERE 4730 LOT IDENTIFIER 261 (A53084)
JOHN DEERE 4730...
