Hydraulic fluid or 30 Wt oil 53 Super C
   / Hydraulic fluid or 30 Wt oil 53 Super C #11
He probably meant the rockshaft arms. If you have Fast Hitch on it, it is a two way cylinder, so one side always acts as a reservoir, and shouldn't cause an overflow.
   / Hydraulic fluid or 30 Wt oil 53 Super C #12
IMHO, there will be a small volume difference extended or not, even on DA due to rod diameter/displacement.
that's why i wouldn't fill one to the 'brim' anyway. :) takes very little oil to stroke those cylinders.
   / Hydraulic fluid or 30 Wt oil 53 Super C #13
True. I usually try to fill it far enough I can touch the oil, measuring with the first joint of my pinky finger, down inside the reservoir. It allows for a bit of expansion also, after the oil warms up.
2017 Claas Jaguar 860 Forage Harvester (A53472)
2017 Claas Jaguar...
sod roller (A52377)
sod roller (A52377)
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
(APPROX 36) 2" X 5" X 21" CHANNEL IRON (A51247)
(APPROX 36) 2" X...
