How much HP needed for a 72" belly mower?
   / How much HP needed for a 72" belly mower? #1
Rob 80
WVA
B2650
Local dealer has a used B2620 for sale, i would like to get a 72" belly mower but does that model have enough power for a 72"?
   / How much HP needed for a 72" belly mower? #2
Not sure if it has the power or not. I don't think KUBOTA makes a 72inch MMM for that model. maybe they don't make it for the reason of it being underpowered. If you bought a 72 inch mmm you might have to change and/or fabricate new lift bracket attachments for it in order to be able to lift it on that tractor
   / How much HP needed for a 72" belly mower? #3
Can't speak for the 2620 but I have a 72 mmm for my b2650 and it does fine, it can mow as fast as I can stand to ride. Field is anything but smooth. Haven't had it bog down, does better then my old Husqvarna 26hp with a 54 inch deck winch I would end up crawling in a few areas with real dense growth.
   / How much HP needed for a 72" belly mower? #4
How did you find a 72 inch MMM for it?
   / How much HP needed for a 72" belly mower? #5
Looks like Kubota now makes a 72 MMM for the 2650 but they didn't for the 2620
   / How much HP needed for a 72" belly mower? #6
Yes, got it from the dealer. Cuts nice too
I just don't want to be under powered after suffering with a 42" 19HP cub cadet for 8 yrs. In tall grass i have to go 1 mph then go over it a few more times before it would cut it. I'm surprised that 19.5 pto is enough for a 72" deck.
   / How much HP needed for a 72" belly mower? #8
The answer is it depends on how thick the grass is but for normal summer conditions it does not take much HP to cut grass. I have a B7800 with a six ft belly mower and can go through anything with it with no trouble. Sometimes I pull a seven ft rear finish mower and I barely know it's back there. Sharp blades help the issue.
   / How much HP needed for a 72" belly mower? #9
Is the HP the same at the mid PTO and the rear PTO?
   / How much HP needed for a 72" belly mower? #10
I have a 60 inch mmm for my B2620. It cuts fine. I didn't know there was a 72 inch mower available. That's 6'. Could it be someone confused 60 inches with 6 foot?
B2620 available attachments .
You said belly mower. You could get a 6' rear mount finish mower . But the practicality will depend on how tall and thick the grass is. If you cut frequently it would probably work.
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
2021 John Deere R4038 Sprayer (A53485)
2021 John Deere...
Wooden Rocking Chair (A55853)
Wooden Rocking...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
