How much HP needed for a 72" belly mower?
   / How much HP needed for a 72" belly mower? #11
Is the HP the same at the mid PTO and the rear PTO?
Not sure I understand the question. The engine powers both but the mid pto is geared to run approx 2000 rpm, the rear has 2 speed options one is 540 and the other option is higher speed rpm but I don't recall.
   / How much HP needed for a 72" belly mower? #12
So both the mid and rear PTO are 19 HP for the B2620? For some reason I have always kind of assumed the mid PTO would be 26 HP and the rear PTO would be 19 HP on the B2620 for example, but I guess they are both 19HP.
   / How much HP needed for a 72" belly mower? #13
I'm betting the rear pto has more HP/torque than the mid, it's all about the gearing!
SR
   / How much HP needed for a 72" belly mower? #14
Looking at Kubota parts on line: There is no 72mmm listed in the parts. Just a 54" and 60".:rolleyes:
   / How much HP needed for a 72" belly mower? #16
I just don't want to be under powered after suffering with a 42" 19HP cub cadet for 8 yrs. In tall grass i have to go 1 mph then go over it a few more times before it would cut it. I'm surprised that 19.5 pto is enough for a 72" deck.
There will be no comparison between your 19hp gas Cub and what you are now considering. A 60" pto drive shaft deck on the B2620 will be way more productive and powerful than your Cub 42" deck. Again no comparison. For a 72" deck you probably would have to jump up one size to a B3200. Or the new B2650 if no b3200's are available.
   / How much HP needed for a 72" belly mower? #17
I still think it was a 60 " belly mower, not a 6'.
B2620 max belly deck is 60 inch. Local dealer had one for sale with a 72 inch rear finish mower.
B2650 and B3350 have 72 inch belly mowers. Is there any differance in the B2650 and B3350 besides the extra HP?
   / How much HP needed for a 72" belly mower? #19
My 17 hp B7200 does fine with a 60 belly mower. My F2560 is 25 hp with a 60 inch deck. I have yet to find grass that will bog this mower down. If you can push it over it, it will cut it. Diesel power is no comparison to gas.
   / How much HP needed for a 72" belly mower? #20
Ok, it was not a 72" belly mower on the B2620 but a rear finish mower. I would test drive the unit and mow some tall thick grass. It would probably be fine.
I don't have experience with the 2650 or 3350. Check specs on Kubota.Com.
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
SKLP Pipe Crimping Machine (A57149)
SKLP Pipe Crimping...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A56859)
1990 21ft Center...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
