Massey 1020 alternator
   / Massey 1020 alternator #1
Dave1158
Brooklet ga
Massey 1020
I have a massey 1020 with with a 6 wire (red,yellow,green,black, blue and blue)voltage regulator pn-RS5104 and a 2 wire alternator pn-GP9153. The 2 blue wires on the voltage regulator connect to the 2 wire alternator. Does anyone know if those 2 wires must connect to a specific wire on the alternator?
   / Massey 1020 alternator #2
Hi Dave, congratulations on your first post here.
Don't be put off by slow replies because when you do get a reply it is usually good information. Eventually you'll get a response, so hang in there.
I have a Massey Ferguson 1010. It's probably very similar to your 1020 in many ways and probably shares many parts. I have a manual that I think contains a wiring diagram or schematic that I can check later today and will see if it helps.
   / Massey 1020 alternator #3
I have a Massey Ferguson 1010. I have a manual that I think contains a wiring diagram or schematic that I can check later today and will se if it helps.
The MF1010 Wiring Diagram shows the 2 Blue wires going to the alternator, each connected to opposite ends of a coil in the alternator. There is no indication on the diagram other than that the 2 blue wires connect to the alternator. HTH. C;lem
   / Massey 1020 alternator #5
Thanks Workstead
Hi Dave. In my reply to you last September I said that sometimes it takes a while to get a reply, but the information is usually good. You just proved the accuracy of that statement! :) Clem
6 Cubic Yard Dumpster (A55851)
6 Cubic Yard...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2011 Ford F150 Ext. Cab Pickup Truck (A55973)
2011 Ford F150...
2018 VOLVO EC480EL EXCAVATOR (A52707)
2018 VOLVO EC480EL...
2020 DRAGON ESP...
