Massey 1020 alternator
   / Massey 1020 alternator #1
Dave1158
Brooklet ga
Massey 1020
I have a massey 1020 with with a 6 wire (red,yellow,green,black, blue and blue)voltage regulator pn-RS5104 and a 2 wire alternator pn-GP9153. The 2 blue wires on the voltage regulator connect to the 2 wire alternator. Does anyone know if those 2 wires must connect to a specific wire on the alternator?
   / Massey 1020 alternator #2
Hi Dave, congratulations on your first post here.
Don't be put off by slow replies because when you do get a reply it is usually good information. Eventually you'll get a response, so hang in there.
I have a Massey Ferguson 1010. It's probably very similar to your 1020 in many ways and probably shares many parts. I have a manual that I think contains a wiring diagram or schematic that I can check later today and will see if it helps.
   / Massey 1020 alternator #3
I have a Massey Ferguson 1010. I have a manual that I think contains a wiring diagram or schematic that I can check later today and will se if it helps.
The MF1010 Wiring Diagram shows the 2 Blue wires going to the alternator, each connected to opposite ends of a coil in the alternator. There is no indication on the diagram other than that the 2 blue wires connect to the alternator. HTH. C;lem
   / Massey 1020 alternator #5
Thanks Workstead
Hi Dave. In my reply to you last September I said that sometimes it takes a while to get a reply, but the information is usually good. You just proved the accuracy of that statement! :) Clem
UNUSED FUTURE FT-X39 39" HYD TRENCHER (A57193)
UNUSED FUTURE...
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55315)
2019 Krause...
2010 Chevrolet Tahoe SUV (A56859)
2010 Chevrolet...
1979 TRIM 102" X 42' FLATBED TRAILER (A57192)
1979 TRIM 102" X...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
