Clutch malfunction on 2910i
   / Clutch malfunction on 2910i #1
jconinc
I have a Branson 2910i, I just finished some work. I parked the tractor and put it in neutral. When I released the clutch pedal it only came out about an inch or so and seemed to hit a hard stop. I can push down the pedal and when I release foot pressure the pedal does start to come up - but hits the hard stop.
The main gear shift lever seems to be functioning. The shuttle lever seems to be functioning.
I moved to secondary gearshift from "2" to "1" but now it will not move back.
Any ideas on what might be the problem?
Thanks
OK - found the problem. Spring had broken, fallen down and was blocking the clutch pedal from fully releasing. Everything is now working - clutch and gearshifts.
So, now my questions are - since the clutch is working properly does that mean there are two return springs? I have a service manual and it only shows one. The pedal actually pretty much feels just as it did before this happened. Is there another spring up there other than the clutch return spring?
Thanks.
Thanks
   / Clutch malfunction on 2910i #3
Thanks.
My 3820i has two springs side by side and I had to replace one in 9 years. That's the only part on the tractor that I have had to replace. Awesome tractor, and I work my tractor, It's not a toy to dress up my garage.
Can it be done by just reaching under the "dash" or do you have to remove the dash?
   / Clutch malfunction on 2910i #5
I believe I did mine without removing the shrouding, but not certain.
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2010 Chevrolet Malibu LTZ Sedan (A51694)
2010 Chevrolet...
JLG 1930ES ELECTRIC SCISSOR MAN LIFT (A51246)
JLG 1930ES...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2023 Ace Cargo 6x12 Food Trailer (A51572)
2023 Ace Cargo...
2022 John Deere 8R 310 MFWD Tractor (A53342)
2022 John Deere 8R...
