Clutch malfunction on 2910i
   / Clutch malfunction on 2910i #1
jconinc
I have a Branson 2910i, I just finished some work. I parked the tractor and put it in neutral. When I released the clutch pedal it only came out about an inch or so and seemed to hit a hard stop. I can push down the pedal and when I release foot pressure the pedal does start to come up - but hits the hard stop.
The main gear shift lever seems to be functioning. The shuttle lever seems to be functioning.
I moved to secondary gearshift from "2" to "1" but now it will not move back.
Any ideas on what might be the problem?
Thanks
OK - found the problem. Spring had broken, fallen down and was blocking the clutch pedal from fully releasing. Everything is now working - clutch and gearshifts.
So, now my questions are - since the clutch is working properly does that mean there are two return springs? I have a service manual and it only shows one. The pedal actually pretty much feels just as it did before this happened. Is there another spring up there other than the clutch return spring?
Thanks.
Thanks
   / Clutch malfunction on 2910i #3
Thanks.
My 3820i has two springs side by side and I had to replace one in 9 years. That's the only part on the tractor that I have had to replace. Awesome tractor, and I work my tractor, It's not a toy to dress up my garage.
Can it be done by just reaching under the "dash" or do you have to remove the dash?
   / Clutch malfunction on 2910i #5
I believe I did mine without removing the shrouding, but not certain.
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2019 HINO 195 16 FT BOX TRUCK WITH LIFT GATE (A52576)
2019 HINO 195 16...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
