Does FEL have to come off to replace clutch?
   / Does FEL have to come off to replace clutch? #11
:laughing:
Mike,
Glad you see the humor in my post.:laughing: A few years ago, I thought I would have to have my clutch replaced. The shop I was thinking of letting do it, said all the subframes had to come off. Since I have a backhoe too, I was dreading removing all that. The backhoe subframe is 1 inch thick plate. Instead I just adjusted the clutch and all is fine.:cool:
hugs, Brandi
Thanks for the replies and your advice. Looks like the loader will be coming off before the tractor gets split. I will start another thread for the smartest and safest way to do this on the 1250.
Clem
   / Does FEL have to come off to replace clutch? #13
Clem
Clem,
When you get the new thread started.........Please put a link to it here on this thread.
hugs, Brandi
   / Does FEL have to come off to replace clutch? #18
Mike,
hugs, Brandi
Yep no worries. You have a large tractor, the OP is in the middle ground with mine small. My point was the loader stopped the front end from moving away while trying to re-join the pieces. Obviously they are not all created equal.
Looking back at the pictures I see I moved the front end around not the rear. I think I used the loader for leverage and the frame as a jacking point. Man the memory is an odd thing. Over 7 years ago, wow.
   / Does FEL have to come off to replace clutch? #19
Yep............memories. Last Christmas vacation I helped a good friend change his Ford F250 engine out in my barn. I kept trying to remember R&R my 6 cylinder out of my F250 over 25 years ago. Some times............you just can't remember it all!
hugs, Brandi
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
40' CONTAINER (A57192)
UNUSED FUTURE CAT 301 EXCAVATOR ATTACHMENT SET (A57193)
UNUSED FUTURE CAT...
2013 Ford F-150 Ext. Cab Pickup Truck (A55852)
2013 Ford F-150...
