Does FEL have to come off to replace clutch?
   / Does FEL have to come off to replace clutch? #11
:laughing:
Mike,
Glad you see the humor in my post.:laughing: A few years ago, I thought I would have to have my clutch replaced. The shop I was thinking of letting do it, said all the subframes had to come off. Since I have a backhoe too, I was dreading removing all that. The backhoe subframe is 1 inch thick plate. Instead I just adjusted the clutch and all is fine.:cool:
hugs, Brandi
Thanks for the replies and your advice. Looks like the loader will be coming off before the tractor gets split. I will start another thread for the smartest and safest way to do this on the 1250.
Clem
   / Does FEL have to come off to replace clutch? #13
Clem
Clem,
When you get the new thread started.........Please put a link to it here on this thread.
hugs, Brandi
   / Does FEL have to come off to replace clutch? #18
Mike,
hugs, Brandi
Yep no worries. You have a large tractor, the OP is in the middle ground with mine small. My point was the loader stopped the front end from moving away while trying to re-join the pieces. Obviously they are not all created equal.
Looking back at the pictures I see I moved the front end around not the rear. I think I used the loader for leverage and the frame as a jacking point. Man the memory is an odd thing. Over 7 years ago, wow.
   / Does FEL have to come off to replace clutch? #19
Yep............memories. Last Christmas vacation I helped a good friend change his Ford F250 engine out in my barn. I kept trying to remember R&R my 6 cylinder out of my F250 over 25 years ago. Some times............you just can't remember it all!
hugs, Brandi
Kubota L4701 (A53317)
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2008 Ford Taurus SEL Sedan (A55973)
2008 Ford Taurus...
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A56858)
2017 Freightliner...
