New Kioti NX5010 owner.
   / New Kioti NX5010 owner. #1
twospoons
Murfreesboro, TN
Kioti NX5010
I just pulled the trigger on my first tractor. I have spent months researching different brands and options. I want to thank EricTheOracle for posting really good videos about his tractor.
We just purchased 50+ acres in middle TN and yesterday the tractor arrived. I'll post some videos of what my impressions are and what not. I'm by no means an expert operator or owner, I typically learn by doing tons of research and doing. I do feel like a kid when moving dirt with this thing though :)
The main usages will be building roads, moving dirt, prepping house sites, digging ditches.
I got the NX5010 HST with cab. 6 foot cutter, box blade, pallet forks, front loader (duh) and backhoe.
I'm in the process of searching for good UTF oil for this tractor, and for my 50 hour service I plan to switch out to Shell Spirax S4 TXM. It's pretty expensive, so if there are better options available please feel free to chime in!
I'll make better quality videos in the future, but here is the first;
https://www.youtube.com/watch?v=Ela4a6f564w
   / New Kioti NX5010 owner. #2
You've got to be pretty pleased with yourself!
I've been using Mobilfuild 424. I have no local source and no alternative that I've found. Lacking an oil lab nearby, I have no idea where to go to find out. I've looked all over the internet and I haven't found anything I can easily get my hands on so hopefully a fresh set of eyes will be able to dig something up!
I liked your video.
Can you do me a favor? Can you take a couple of detailed shots as to how Kioti locates the mounts for the subframe? I don't have a backhoe, but if I trip over a used one, I'd like to know how where Kioti locates their backhoe mounts on the 2485, so I know where to locate the mounts for any subframe I fab up for it.
Thanks, and enjoy your new Kioti!
   / New Kioti NX5010 owner. #3
Congats! but i'm confused as you show a 6010 in the video.
   / New Kioti NX5010 owner. #4
6010 on the loader but if you look quick 5010 on tractor
   / New Kioti NX5010 owner. #5
Congratulations, Twospoons!
   / New Kioti NX5010 owner. #7
Agh!!!:duh::pullinghair:
No reason to Agh. The loader says KL6010 and tends to obscure the NX5010 logos on the sides of the rear lower hood.
Anyway, all of the NXs have KL6010 loaders and the tractors are identical except the 5510 and 6010 have slightly bigger tires and are cat 1 and 2 compatible three points.
Without cross referencing part numbers, I strongly suspect a EROM flash is what is different in 45-60 hp versions, much the same as modern boat motor and some (some) car engine families that share the same block.
Thank you. I took a video of the bracket and how it's mounted. I'll take picture with a better camera if you need more details and not just a general idea.
https://www.youtube.com/watch?v=BbzDvu9Gcoo
The only place I can find Spirex S4 TXM is online. The dealer said any UTF rated oil is sufficient, but I don't mind spending a few extra $ on good oil.
   / New Kioti NX5010 owner. #10
[snip]
The Traveller Premium Universal Hydraulic Fluid at TSC is reportedly made by Warren. It's what I am using in my NX4510HST cab. Can tell no change in performance from what the tractor was delivered with.
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
Kubota BX22 TLB Compact Tractor (RUNS) (A50774)
Kubota BX22 TLB...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
Towable Jump Pack (A50774)
Towable Jump Pack...
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
