72" core aerator to big for bx25?
   / 72" core aerator to big for bx25? #1
Mcaveman
Maryland
Own Z121S, BX25 purchased w 35 hrs
Found one local in good shape, is it to much for my bx?
   / 72" core aerator to big for bx25? #2
it depends on the aerator , I have a bx 24 with a 48 inch ,its great . I also have a NH 1925 with a ryanair 72 inch ,it weighs close to 1500 lbs . The bx 24 wouldnt be able to even lift it .
   / 72" core aerator to big for bx25? #3
If its 600 lb or less you should be able to pick it up no problem. Not sure if 17.5hp PTO is going to get the job done though.
   / 72" core aerator to big for bx25? #4
Too big, I pull a 50" with my B2620 and to have enough weight for proper core depth you won't be able lift it. My tractor gets light in the front even with the loader on. Every 72" core aerator I've seen is pretty hefty even without weights.
I would look for a 48" for a bx
Thanks guys I picked up a used land pride 48" and so far pretty happy with it.
1264 (A50490)
1264 (A50490)
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
Wooden Dump Barge Wagon (A50515)
Wooden Dump Barge...
2015 TRANSMASTER LOWBOY TRAILER (A51222)
2015 TRANSMASTER...
1987 FORD 2110 TRACTOR (A51222)
1987 FORD 2110...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
