Brush pile near pond
   / Brush pile near pond #11
Good or bad for the pond I would burn it. It's easier to move some ash if it is determined to be detrimental to the pond.
   / Brush pile near pond #12
Id burn it too. Then scrape the ash out with a box blade. You didn't say how big your pond was but I would not think you will effect it much.
   / Brush pile near pond #13
I agree with Sodo. If you take a rope/chain/cable, and strategically thread it through the brush pile and give it a pull, 90% will come out in one gob. Then burn it safely on high ground.
   / Brush pile near pond #14
One thing that nobody has mentioned yet is that the original owner may have put the brush in the ditch as a form of erosion control.
   / Brush pile near pond #15
Could be but doesn't look like a lot of water flows there.
As you pull a gob out, you can toss the stuff that remains - ontop of the gob that separates (if it does separate). And burn small piles in the ditch (that don't burn so hot for so long). I've moved & burned so much brush in the past few years it boggles my mind - easily 50 times that. I have a pile half that big right now. I'd just start into it and see how it goes. If you have a tractor with FEL and cable/rope/chains I'd certainly recommend using what you have. You could be a 1/4 done in the time it takes to plan another method.
If you must use hydraulics consider to rent a mini-excavator with a thumb. Probably $250/day + delivery charge. You can set it up on the bank, then build a smaller fire. Sometimes I make several piles but burn just one, and shove successive piles into the (hot) ashes with my FEL. They burn quickly ontop of hot ashes (in stages) and makes only one dead spot.
   / Brush pile near pond #16
When you burn plant matter the nitrogen stored in the plant is released quickly back into the soil. This is the reason prairie grass is burned. To release the nitrogen to promote faster grass growth. Fast cheap fertilizer.
When plants decay naturally the release is gradual.
Not to be argumentative, but it seems to me that this does not apply to the OP's situation. If he burns the brush pile, he is going to end up with ashes that then may wash into the pond. It seems to me that the critical question is the chemistry of the wood ashes.
Much wood ash contains calcium carbonate as its major component, representing 25or even 45 percent. Less than 10 percent is potash, and less than 1 percent phosphate; there are trace elements of iron, manganese, zinc, copper and some heavy metals.However, these numbers vary, as combustion temperature is an important variable in determining wood ash composition. All of these are, primarily, in the form of oxides.
For a long time, wood ash has been used in agricultural soil applications, as it recycles nutrients back to the land. Wood ash has some value as a fertilizer, but does not contain nitrogen. Because of the presence of calcium carbonate, it acts as a liming agent and will deacidify the soil by increasing its pH.
https://en.wikipedia.org/wiki/Wood_ash
Steve
   / Brush pile near pond #17
Steve
Thanks, I was fairly sure tht was the case. As for nitrogen, any of that would be released in the smoke or to the air.
I heat witih wood, 6-7 cord/yr. Spread the ashes in fairly small areas of the yard and for sure after 30+ years haven't seen any show of excess nitrogen.
Harry K
Harry K
   / Brush pile near pond #18
As of now, moving it is not an option. I have a tractor with FEL, but no grapple. The ditch is about 40 feet long, six feet wide and about 2-5 feet deep. It's a major eye sore and I've been trying to clean up this property. It may have wait until I get a grapple.
That's a very small brush pile. I'd just burn it.
I thought He may have done it for erosion at first but actually he was just kind of lazy. I have found sheets of barn tin, rebar, pipe, 2x4s, romex, chicken wire, barbed wire and tons of other crap just strewn all over the place (which most of it was found while trying to mow). The ditch was just convenient I believe.
Thanks for all of the replies, guys. As for now I think I will try to remove the brush. There are a lot of pretty big logs from dead hickory in there as well. Too many weeds have grown over it, so hard to see in the pics.
   / Brush pile near pond #20
I would burn it where it sets,we actually burn in the draw heading towards the pond every year. We take all the dead trees/limbs from the pasture all year,safest place for us to burn. Hasn't harmed fishing never any kills,the big burnt trees will end up under water if get a lot of rain and will wait until it goes down and stack more on top try get burned down.
image.jpg looks like will have to pull this one back floated down from all the rain had in june
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
JOHN DEERE 437E...
40 SEA CONTAINER (A53843)
40 SEA CONTAINER...
RIDGID 141 THREADER (A53843)
RIDGID 141...
40' CONTAINER (A51244)
