Replacing tines on a King Kutter rototiller
   / Replacing tines on a King Kutter rototiller #11
If you have a pressure washer, clean that tiller out real good before you start.
This will make the work much, much more pleasant.
Helps to have the tiller mounted to the 3pt hitch & raised.
Also helps to remove the rear gate.
Of course, it goes without saying that all safety precautions will be observed.
This includes blocking the tiller from the bottom, if it's lifted up.
Once clean, leave it until it's dry, then give all the nuts a good shot of Kroil, Liquid Wrench, ATF/Acetone, or whatever your poison and let it set overnight. After the solvent has had a chance to soak in, loosen the fasteners by holding the bolts & turning the nuts until they break free. As sixdogs said, a pair of box end wrenches, long pattern, if you have them, will be your friend on this job.
Should go easy as pie; simple as cake.
-Jim
Thanks guys. Yep, already planned to pressure wash first. Hopefully will tackle this soon.
Sent from my iPad using TractorByNet
   / Replacing tines on a King Kutter rototiller #13
Rather than blocking it up, I put a 3" ratchet strap around the top of the ROPS and hooked to the tiller. Tie the door all the way open and it works for me. I sit on a plastic chair and wrench away.
Good idea! Wanna come over and help? I'll buy the beer!
   / Replacing tines on a King Kutter rototiller #15
You will find --if you don't overthink it--that tines are no big deal and will take a only a few hours. Piece of cake.
Last winter I changed 110 tines that were 2 5/8" apart, on my slit seeder. There was barely enough room for the wrench and, because it was so tight and difficult took me a week of off and on to get them changed.
   / Replacing tines on a King Kutter rototiller #16
And concerning the loosening solvent of your choice (I prefer PB B'laster or Kroil). I've had parts that seemed to be welded together. I spray or dribble a little on, let it sit a couple of days, attempt to loosen, repeat several times. Occasionally it's taken weeks and 4 or five "bathings" along with "bangings" to get a particularly stubborn bolt undone. So if you've got the time let it sit.
And I ripped this
A study done by Machinist"s Workshop magazine in their April 2007 issue looked at different penetrating oils to see which one did the best job of removing a rusted bolt by measuring the pounds of torque required to loosen the bolt once treated. If the study was scientifically accurate, it turns out a home brew works best!
Here"s the summary of the test results:
Penetrating oil ..... Average load
None ...................... 516 pounds
WD-40 ................... 238 pounds
PB Blaster .............. 214 pounds
Liquid Wrench ...... 127 pounds
Kano Kroil ............. 106 pounds
ATF-Acetone mix....53 pounds
from PB Blaster vs Kroil - Yesterday's Tractors, don't know the validity.
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56438)
2016 KBH...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
New Holland 650 Hay Baler (A53317)
New Holland 650...
2009 Ford F-550 4x4 Ext. Cab Brush Fire Truck (A59230)
2009 Ford F-550...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
