FEL Cylinder gone flip floppy BX24
   / FEL Cylinder gone flip floppy BX24
To find out if it is leaking.
It's not leaking and the fluid levels fine. Fluid was changed per schedule. I take good care as far as maintenance goes.
Perplexing to me why it does this. Not sure why its normal when low temp but goes slack after extended working(heat).
Thanks for looking at this.
   / FEL Cylinder gone flip floppy BX24 #13
Have the filters and screens been looked at recently?
   / FEL Cylinder gone flip floppy BX24 #14
Suction air leak. Frothing caused by entrained air goes away during quiescence.
Any ideas where this suction leak would be? At the FEL quick connects likely?
   / FEL Cylinder gone flip floppy BX24 #16
You would typically have pressure at those.
,,,, Suction is always present at the hyd pump intake. Usually the pump intake line will include a strainer and filter, and depending on the tractor, some large piping with rubber clamp joints. Every joint is a potential source to ingest air. Things truout -- filter, strainer, tubing joints, ect must seal. Anything on the outside may get disturbed and begin leaking. Filter may be loose or seal compromised by a small piece of debris. It doesnt take much to put the oil in a froth. When it sits, the sump clears up and its better for awhile -- BUT air is still in the lines, coalesced into large bubbles, and you may notice slight hesitance or a jerk in motion as you 1st raise the loader as those bubbles pass thru the valve back to the reservoir.
I'll look it over before next job start. Waiting for things to dry out and its stranded under shed in a sea of very soft ground. Thanks
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2014 Chevrolet Impala Limited Sedan (A55853)
2014 Chevrolet...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2011 Case IH Steiger 335 AFS Tractor (A53485)
2011 Case IH...
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
2011 DOOSAN G40 GENERATOR (A53843)
2011 DOOSAN G40...
