Diesel Exhaust Burns Eyes
   / Diesel Exhaust Burns Eyes #11
It's more than likely the pump, i had a 74 model identical to yours & that's what the problem was, i've been wrong before though.
Ronnie
What was wrong with your tractors IP? I can't envision how an IP alone could cause burning eyes unless the speed advance wasn't operating properly.
Thanks,Jim
Ronnie
Seems that it's over my head from these posts so I'm taking it to the shop this week. I will let you fine folks know the outcome. It's also smoking (white), so hopefully it will solve both problems.
   / Diesel Exhaust Burns Eyes #13
When you say "shop", is it a Deere shop or your local diesel shop?
Not that it makes a difference if the shop has access to the proper settings and procedures for dialing in your engine.
I have a shade tree guy. He did the overhaul for me and it didn't start this until it broke in (about 10 hours). I'm taking it back to him for a "tune". If he can't do it than I'll go to Bridgeport eqt. (Dealer). I'm pretty sure he'll fix it the same day though unless he needs to order parts.
   / Diesel Exhaust Burns Eyes #15
Don't overlook the obvious. Is the air filter clogged?
   / Diesel Exhaust Burns Eyes #16
Thanks,Jim
Jim, i'm not sure, i had been thinking about getting another tractor, he had one there & i traded for it, actually got what i paid for the 820 twelve years earlier. I know he had the pump rebuilt before he sold it.
Ronnie
   / Diesel Exhaust Burns Eyes #17
Ronnie
It's possible it was IP repair that resolved your tractors problem but changing IP timing from where it had been set prior to the repair.
   / Diesel Exhaust Burns Eyes #18
My 1972 Deere 820 tractor has been burning what smells like raw fuel. It burns my eyes when Im backing up and I can taste raw fuel. The tail pipe is down low for orchard use and Id like to leave it there. It just started doing this after an overhaul which did not include new injectors. Any help much apprectiated.
It might be a good idea to have the engines compression verified in addition to the IP timing,
just to be sure the rebuild is meeting new engine specs.
unburned diesel (white smoke) is possible with insufficient compression or late fuel injection events
best wishes- Hopefully it is something simple.
10' CONTAINER (A51248)
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
2003 Acura Tl Sedan (A51694)
2003 Acura Tl...
1982 LeeBoy Motor Grader (A53472)
1982 LeeBoy Motor...
JOHN DEERE 17P LOT IDENTIFIER 212 (A53084)
JOHN DEERE 17P LOT...
PALLET OF MISC SIZE EXPANDED METAL (A51247)
PALLET OF MISC...
