How to measure top link
   / How to measure top link #1
Mike from MI
Bellevue,Mi
Kubota l3200 hst 2014
Extended all the way out and center hole to center hole ?
   / How to measure top link #2
Many I see list both dimensions-fully closed and fully open. Otherwise you could get a match one way and not the other.
Like this one: 17 to 25 1/2
Top Link, Cat 1, 13 Center Tube Length
Bruce
Building ballast box out of plastic barrel. I need a longer top link to keep barrel level when lifted to where lower arms are level.
   / How to measure top link #6
As noted, typically listed are the collapsed and the extended lengths. Take a look here. They usually have a good selection at a reasonable cost. :thumbsup:
Thanks for the link just ordered one for much less than others I have looked at with shipping.
   / How to measure top link #8
Mike, you checked the retracted length too, right? Will the new longer link give you the retraction you need when you're using implements other than the ballast barrel, e.g. a York rake or a rear blade that you want to carry high for clearance from time to time? But I guess if not, you could always just swap it out for the original when necessary.
My current top link works well for my other improvements, so I'll just swap out when using ballast, probably just leave attached to ballast barrel.
Thanks everyone for the great input.
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A55853)
2022 McConnel...
2009 BMW 335i Coupe (A55853)
2009 BMW 335i...
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
1991 Cummins NT-855-G5 250kW 3-Phase Diesel Generator (A55851)
1991 Cummins...
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
PumpJack Brand Pump Jack (A55315)
PumpJack Brand...
