How to measure top link
/ How to measure top link #1
Mike from MI
Bellevue,Mi
Kubota l3200 hst 2014
Extended all the way out and center hole to center hole ?
/ How to measure top link #2
Many I see list both dimensions-fully closed and fully open. Otherwise you could get a match one way and not the other.
Like this one: 17 to 25 1/2
Top Link, Cat 1, 13 Center Tube Length
Bruce
Building ballast box out of plastic barrel. I need a longer top link to keep barrel level when lifted to where lower arms are level.
/ How to measure top link #6
As noted, typically listed are the collapsed and the extended lengths. Take a look here. They usually have a good selection at a reasonable cost. :thumbsup:
Thanks for the link just ordered one for much less than others I have looked at with shipping.
/ How to measure top link #8
Mike, you checked the retracted length too, right? Will the new longer link give you the retraction you need when you're using implements other than the ballast barrel, e.g. a York rake or a rear blade that you want to carry high for clearance from time to time? But I guess if not, you could always just swap it out for the original when necessary.
My current top link works well for my other improvements, so I'll just swap out when using ballast, probably just leave attached to ballast barrel.
Thanks everyone for the great input.
/ How to measure top link #12
Wondering why the attachment points of the weight couldn't be located to roughly a standard pattern.
/ How to measure top link #13
If you must abuse your tractor and need to add a ballast in the rear, you should keep the weight as low to the ground as possible.
/ How to measure top link #14
Depending on the load, in some cases you need to have weight behind the rear tires to fully utilize the front end loader's capabilities.
We have a tractor at work that has to have weight behind the back wheels or the front axle is overloaded when they lift the pusher box that is on the loader.
The pusher box is within the loaders capabilities, but the front axle is overloaded if they pick up the pusher box.
Aaron Z
The attachment point at lower lifting arms are as close as I can get them without touching arms were they curve in.
Depending on the load, in some cases you need to have weight behind the rear tires to fully utilize the front end loader's capabilities. We have a tractor at work that has to have weight behind the back wheels or the front axle is overloaded when they lift the pusher box that is on the loader. The pusher box is within the loaders capabilities, but the front axle is overloaded if they pick up the pusher box. Aaron Z
You hit the nail on the head, will be using with pallet forks and loader work to take stress off front axle.
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A61306)
2019 Takeuchi TL8...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
2017 JOHN DEERE 310SL BACKHOE (A60429)
2017 JOHN DEERE...
iDrive TDS-2010H...
