Ignition Switch
   / Ignition Switch #1
Frank Sorbello
Gold Member
Power Trac PT-422
Lately when I go to start my PT-422, it will click two or three times like a dead battery then it will start to turn over and start. Is that a sign that the ignition switch is starting to go bad. If so does anyone have a part number and source for a new one.
Thank you,
Frank
   / Ignition Switch #2
Try checking to make sure your ground is making good contact
   / Ignition Switch #3
Frank, pull out your volt meter. It can be a bad ground, a bad switch, or a bad starter solenoid.
   / Ignition Switch #4
Mine does the same thing. Its been doing it for a couple years. I'm going to replace my starter solenoid before winter, just to be on the safe side. I may also replace the ignition switch, as it has been frozen with ice a few times in the last two years. At 14 years old, it can't hurt.
   / Ignition Switch #5
Squirt some WD40 into the key slot and work the switch a few times.
Th WD will re dissolve the dry caked lubricant inside and basically overhaul your switch. (it is non corrosive)
   / Ignition Switch #7
check voltage at solenoid when key turned to start and it is clicking.. if it is getting full 12v, then suspect the solenoid.
   / Ignition Switch #8
Don't love WD 40. It attracts dirt and this repair would be temporary in that case.
I was aware of using Electronics cleaner spray, then spraying graphite, that seemed to be the better solution. Costs more, though.
   / Ignition Switch #9
X2 on this one. Use electrical contact cleaner and follow it up with a dry contact lubricant such as graphite, or teflon.
WD40 is "Water Displacement, recipe 40", a light mineral oil and it will attract crud into the switch that you don't want.
A volt meter will certainly help you figure out if you are getting 12V at the starter solenoid, or not, and you can work backward from there.
Good luck,
Peter
   / Ignition Switch
I did squirt WD40 in the ignition slot before I read the later posts. It did not help. I will try using a volt meter to the solenoid.
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
204549 (A52707)
204549 (A52707)
Cushman Electric Cart (A55851)
Cushman Electric...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
