drive over air hose to close gate
   / drive over air hose to close gate #11
You might have to put a board over the hose. A tractor tire might be capable of rolling over a hose without compressing it.
   / drive over air hose to close gate #13
Low tech idea - set a post within reach from your seat with a rope and a couple of pulleys to unlatch gate as you drive through.
I wanted it to be fool proof, in case someone forgot to close gate, including me :)
Thanks for all the replies guys, lots to think about and look into!!
   / drive over air hose to close gate #16
If I was going to the trouble of making a powered gate, I'd have a remote control to open and close it.....
   / drive over air hose to close gate #17
a post with a button on it to push to open and one on the other side to close, (most likely would need 4 posts all equipped with open and close buttons, so one can open or close going or coming,
problem I see with the hose is if two cars one following the gate could close on them or a long trailer,
   / drive over air hose to close gate #18
Any ideas for activation? Like a through beam with reflector? Kinda like a garage door safety sensor. I'm sure they offer them in 12v. Most of them are 110V or 24V.
The through beam would work. You could also stay with your hose idea and may be able to rig up something pressure activated tied to the hose. A pressure switch tied to the hose could trip when you drive over it. Like someone else said make sure you don't use air in the hose because it can compress and may not give the pressure rise you are looking for.
There are probably a dozen different ways to do it, just depends what you have access to and how much you want to spend.
   / drive over air hose to close gate #19
air hose is not filled with actual "air" it is completely full of "fluid" most likely some sort of antifreeze / water mixture. perhaps RV antifreeze. fluid is not compressible, air is.....
All the ones I have seen were just air.
As kids, we had great fun blowing into the end of the open hose to make the bell at the gas station ring, then running off.
I think mrpete222 on youtube did a video on how the milton bell worked.
found it:
http://www.youtube.com/watch?v=mjVz-72r44g&feature=youtube_gdata_player
   / drive over air hose to close gate #20
This switch will do what you want. Use 3/8" air hose and you have to plug the other end, no need for liquid.
Barksdale D1H-H18.
If you are going for a 12v DC latch I would stop by a junk yard and get an electric trunk latch, make sure you get the plug too, will take all the work out of the project.
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2011 BMW X5 xDrive35i AWD SUV (A50324)
2011 BMW X5...
2017 Case CX130D Excavator (RIDE AND DRIVE) (A50774)
2017 Case CX130D...
2018 New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
2018 New Holland...
