IRON HORSE IHT 284 SCREETCHING SOUND
   / IRON HORSE IHT 284 SCREETCHING SOUND #1
luchito
Wolfeboro, NH
iron horse IHT 284
I bot the tractor 2004, used it to ploud snow in my back yard in the winter and sometimes in summer to move fire wood.
Tractor IHT 284 starts fine. I HAVE THIS SCREETCHING SOUND, it may come from the clutch, it comes when I press on the clutch, and it comes and goes. Sound stops when I let go on the clutch. Help with diagnose please!
   / IRON HORSE IHT 284 SCREETCHING SOUND #2
Hi
Welcome to TBN.
Sounds like your clutch thrust bearing has had it. Means you will have to split the tractor to replace if I am right. Not a hard job and you only need simple tools to complete it. But while its apart I would check you clutch plate, pressure plate, pilot bearing etc.
First, thank you so much for taking the time to reply. Fortunately have plenty of tools, what I do not have is mechanical
knowledge, but very high interest in learning. I do not have a trailer to bring the tractor to a mechanic; that means I have to do the job myself. Can you recommend a site that has a videos, like utube, etc that shows how to do this job?
or at a minimun a written detailed procedure for doing the job. Thank you again, we need more people like you.
Louis
micerro@netzero.net
   / IRON HORSE IHT 284 SCREETCHING SOUND #4
Louis
micerro@netzero.net
I think your tractor is like a Jinma. I suggest you contact Affordable Tractors (Tommy is very active in these forums). If it is a Jinma he can supply you with all the parts, manuals and help you will need. If it is not a Jinma he can probably point you in the right direction to get help
   / IRON HORSE IHT 284 SCREETCHING SOUND #5
If you look here you will find a lot of info.........johnstractor
   / IRON HORSE IHT 284 SCREETCHING SOUND #6
   / IRON HORSE IHT 284 SCREETCHING SOUND #7
SOME of these had a grease-able throw-out bearing, but it was not easy to get to & needed a needle greaser. you would have to open up the clutch covers and use a good light to look in at the bearing where the clutch fork pushes. there is a small hole in there that takes a small amount of grease on them to help them live.
M
43023 (A59228)
43023 (A59228)
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
Forklift (A59228)
Forklift (A59228)
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2013 NISSAN NV3500 CARGO VAN (A59575)
2013 NISSAN NV3500...
