7-way plugs....anything better out there
   / 7-way plugs....anything better out there #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
As the title states.
The typical 7-way trailer end plugs I seem to have to replace every 2-3 years. The plastic usually cracks, around that tiny flat head screw that holds the end on. Then when trying to unplug, you are actually pulling the face of the connector out by the wires.
Dont like the design. Couldnt find any 7-way flats that had a metal housing.
Replacing a $10 connector isnt a huge ordeal. just a PITA when if there is something else better I could be using...
   / 7-way plugs....anything better out there #3
Perhaps order a one piece molded plug/cable?
Aaron Z
Yes, like those. I looked and didnt see anything.
Not bad prices either. Thats what the local auto stores want for an all plastic job.
Anyone use them metal ones? Any good?
   / 7-way plugs....anything better out there #5
I've seen many of the Pollak plugs on RV's, but not used one.
Do you have an RV supply you can check instead of auto parts stores?
Bruce
Bruce
Not any around. I'll just order one most likely.
Just seeing whats out there and what others are using. I know alot of TBN members drag trailers around alot. And wondering if everyone just deals with the crap plastic plugs or if they have found better alternatives
   / 7-way plugs....anything better out there #8
I think I got my all metal plug from a Napa store. They didn't have any on display that I liked, so the guy checked and had some styles in back.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
RIMS AND TIRES (A50854)
RIMS AND TIRES...
2013 MAGNUM TRAILER GENERATOR TRAILER (A50854)
2013 MAGNUM...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
1981 LINK BELT HSP 8028 (A50854)
1981 LINK BELT HSP...
