Getting rid of Moles/Voles
   / Getting rid of Moles/Voles #161
When we were kids every couple of years 2 or 3 moles would show up in our back yard. My mother would walk out with a shovel to the end of one of the mole runs and stand quietly for a few minutes. After the mole was sure the danger was gone and he started digging again my mom, seeing the movement in the soil, would simply insert the shovel about 6 inches behind him and pop him out. Simple and effective.
We always had a neat show and tell at grammer school. Poor moles got passed around school by moms 4 kids.
   / Getting rid of Moles/Voles #162
This is the method I've employed with success but I substitute the shovel with a pitch fork. I'm not about to glamourize those little buggers.
It seems the moles in my yard are most active at dusk.
Matt
   / Getting rid of Moles/Voles #164
I was okay with the tunnels, even the occasional mound of dirt, but last night while mowing I see where they have began to develop a condo!
Yeah. Here in the orchard the Gopher Palaces (I call them) are found wherever I backhoe out the stump of a tree that died. They must feel safe there because the discing never went over that spot when there was a tree on it.
It's normal to find up to a cubic foot of soft fine grasses in these cavities. I figure they must be birthing nests. And as I pursue roots outward from the stump it is obvious that major tunnels converge on these cavities. I dig up and disrupt an area at least the volume of a card table, in hopes they will move their headquarters somewhere away from the new tree I plant at that location.
There's nothing more discouraging than going out to water a new tree and see it fall over, rootless, as its basin fills with water. Second only to that, is when I fill a new-tree basin and suddenly the pool disappears down a gopher hole like I pulled the plug from a bathtub ... then I stomp on the gopher run to seal it, ... and sink into the muddy water, clear over the top of of the knee-high milking boots that I wear when watering. Seems they rebuilt their convention center cave right under the new tree. Bah. :irked:
I've told this story before - the gophers here are so bad that plant geneticist Luther Burbank gave up his experimental plots here and moved elsewhere.
He donated his land to the adjacent cemetery. :eek:
   / Getting rid of Moles/Voles #165
I have lost 4 arborvitae to moles ringing the roots. It has been all out war for 4 years to protect the trees. I am gaining the upper hand. I have started trapping on the neighbors yard to stem the tide.
   / Getting rid of Moles/Voles #166
I think it is another govermunt intrusion into our privacy. They probably carry listening devices. There you go.....Drones that look like buzzards circling on high, and moles listening in. :D
   / Getting rid of Moles/Voles #167
I think it is another govermunt intrusion into our privacy. They probably carry listening devices. There you go.....Drones that look like crows and moles listening in. :D
It must be a government plot Mike. There have been a lot of Seagulls circling overhead the last few weeks. There has to be a drone in there somewhere.
   / Getting rid of Moles/Voles #168
Don't know if I have moles or voles but the standard old wooden mouse trap baited carefully with peanut butter seems to work fine for me.
Peanut butter as bait seems to work for most things.
   / Getting rid of Moles/Voles #169
Back when I had moles, before I gave up and moved, I dreamed of little concrete dome things I could move around the yard. Underneath was a trip device and some C-4 [ plastic explosive ]. I was also working on small nuclear device designs... but my therapist said that I should not really go in that direction. Now, I finally rest better at night, since I moved........ [[[ :) ]]]
   / Getting rid of Moles/Voles #170
My moles must be bigger than what you have because I doubt the little mouse trap I am thinking of... wouldn't work on them.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
light tower (A56857)
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
1991 Suzuki LT160 Quad Runner (A59814)
1991 Suzuki LT160...
