RedNeckGeek
Super Member
- Joined
- Jan 1, 2011
- Messages
- 8,451
- Location
- Butte County & Orcutt, California
- Tractor
- Kubota M62, Kubota L3240D HST (SOLD!), Kubota RTV900
I've been mowing on steep uneven ground the past few days and have a problem with the tractor coming to a stop all by itself while traveling in a straight line. Engine speed isn't effected; it's as if I've taken my foot off the Speed Control Pedal causing the tractor to stop. I've also seen this behavior when turning the steering wheel near or at full lock while in four wheel drive while moving. It's almost as if there's some kind of safety cutoff that senses the drive line loading up and disabling the drive train to stop the tractor.
Taking my foot off the Speed Control Pedal and pressing back down in the former direction of travel has no effect, the tractor just sits there. Sometimes pushing the Speed Control Pedal for the opposite direction will cause the tractor to move in that direction, and then the original direction starts to work again. Other times travel in both directions is disabled. I've been able to get it going again by turning the steering wheel from side to side. Sometimes I have to turn the engine off and restart to get going again.
This is more than just a PITA, it's also a safety problem when working on steep ground. The tractor doesn't take off like it was in neutral, but it will move downhill unless I hold it back with the brake. That could be real bad news if the Speed Control Pedal or steering wheel manipulation doesn't restore motion.
I've verified that this is not the Operator Presence Control in the seat acting up by taking my weight off the seat while the PTO is running. When I do, the engine dies unless I sit back down immediately. The engine will die when I lift my butt off the seat even when I'm not using the PTO, so I don't think the PTO has anything to do with the problem. And the problem still happens even when the Bushog is replaced with the box blade.
Sorry if my description is unclear; I'm really not sure how to describe what's happening. Maybe there's a ghost in the machine?
Anybody having similar problems on an M62 or other Kubota tractor?
