Shield Arc
Super Member
My Dynasty 300 almost made a Tig welder out of me. I love it, I just turn it on, and I get results like this! :cool2::cool2::cool2::cool2:I aught to pick up an inverter while I'm at it!![]()
That's a very good idea!Maybe I can press the pedal before I position the torch and start out with gas flow before I ever strike an arc. Is this a possibility?
That's a very good idea!![]()
Yes that has definitely helped. If I can get a quick puddle going and moving the torch quick then ease off it does much better. At least part of my problem is I have sat there and cooked the aluminum. Amperage is never in short supply with this beast lol. Even when I move quick enough it seems there's always a "skin" over the puddle. I guess if I had a/c balance with more cleaning affect that might be not so bad. I was reading at welding tips and tricks and he recommends adding helium with the argon. Can anyone tell me what affect helium has on the process?Also, give it lots of pedal at the start when welding aluminum.
With helium you can really start backing off the amps. I made this weld with 100% helium, on DC. About half the amount of amps if it was with pure argon, and on AC.
You realize that is how Heliarc welding on aluminum got started.![]()
