How much blow-by is too much?
   / How much blow-by is too much?
I agree a 5 ft hog is too big, you're working it at 100% output more often than it was designed for when new.
I can't disagree with this but what's the best way to tell when it's working too hard? Lugging down? Temperature? Oil pressure? I have installed an oil pressure gauge and I have the temperature gauge that I can hopefully install soon. Would temp and pressure give a decent indication of load?
   / How much blow-by is too much? #12
Lugging down is the best method. As long as the radiator is clean it shouldn't over heat running the PTO 540 rpm. You can pull a 5 foot cutter with any tractor capable of lifting it, but you will have to go slow. Your tractor if I read the specs right has 19.7 PTO hp. I have pulled a 5 foot cutter behind a Kubota L2550 and a Kioti CK25. I wouldn't want any less cutter behind either tractor.
   / How much blow-by is too much? #13
I think the simplest measure of working it too hard is if it won't hold its rpm. If your cooling system is in good shape and you have good oil in it etc then loading it sometimes until it will just barely hold its rpm won't hurt anything, that's what it was designed to do. Oil and temp gauges should remain in the 'reasonable' range if the cooling system meets spec.
My experience has been I've had to shift down a gear to mow back up a gentle slope that I could easily mow in the downhill direction. Just climbing the slope loaded the rig - with 4 ft mower - too hard if I was cutting tall wet grass. I doubt I could mow that stuff in either direction taking a full cut with a 5 ft mower.
Since you already have the 5 ft mower - I would take less than a 5 ft new cut, overlap the previous cut, wherever there is heavy growth. You'll find a balance with what it is capable of.
   / How much blow-by is too much? #14
My YM14 has pretty bad blowby. It choofs like a train out the vent tube when it's hot. It is a little touchy to start in winter but not so bad in summer. Uses a little oil but by the way it smokes when throttled up you'd think it would use lots but it doesn't. It's been like this for years and probably will continue to stay like it too.:thumbsup: Keep it a runnin'.......
   / How much blow-by is too much? #16
5foot is too big in tall and thick grass but if you bush hog a few times a year and do not have overythick grass these ym240/2000 can easily run a 5 foot one. I do all the time now and unless its like i stated above its fine and can handle it, no having to over rev the tractor no dragging it down on slight hills or when i cut grass.
If i think its thicker i just pinch over and take a 3.5-4 foot bite.
You will see mist and like a small exhaust stream out of your blow by tube on the right side of the tractor if its really bad. I have the same thing happen as you describe when i pull the dip stick when running. But think of that crank shaft rotating through that oil at the speed it does!!! I do have a small amount of blow by but to see it you have to have the sun light just right to see it out of the tube and you can feel or maybe not a sligt air movement if you put you finger in front of the tube at Operational RPMs.
I dont think i am looseing any noticeable amount of power at this point and to me is certainly acceptable. There is a youtube video people always link to to show a yanmar with excessive blowby. THe tube looks like a tiny exhaust pipe blowing out grey exhaust!
   / How much blow-by is too much? #17
i bet thats the video winston...was pretty sure you were the one who always posts it. I have not clinked the link here to confirm but i bet its the same video i am thinking.
Oh i need to add that my tractor inbwtween 50 hour oil changes i can not tell the oil level changes one bit.
   / How much blow-by is too much? #18
If it starts, runs and doesn't more than a quart of oil every 3-4 tanks of fuel . Don't worry about it.
   / How much blow-by is too much? #19
Make sure you have the right amount of oil in it. Not uncommon to have someone stick any old dipstick in an older piece of equipment just to plug the hole.
   / How much blow-by is too much? #20
Good point. If we're still talking about a YM240/YM2000 here - my YM240 takes four quarts to show halfway up the hi/low region on the dipstick.
That's how I run it. If I were running it flat-out in hot weather I would add more to top it up, but my use for this one is mostly operating the backhoe or just puttering around carrying something in the loader, not really stressing it.
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2 Bottom Plow (A57454)
2168 (A58376)
2168 (A58376)
2014 Case 601D Directional Drill (A57453)
2014 Case 601D...
2004 Chevrolet C5500 Flatbed Service Truck with crane, VIN # 1GBE5C1214F513547 (A57453)
2004 Chevrolet...
36FT. B-Tek Centurion 100 Ton Digital Modular Commercial Truck Scale (A56858)
36FT. B-Tek...
