I would cut the existing floor, dig down 8" and put rebar across the floor and put the ends into the existing floor for a little more weight and strength and maybe a little more leverage against a strong wind..
Then weld 8' rebar, or as high as you want the ceiling to each of the lateral floor rebars. I did one this way and also put heavy cattle panels to make a heavy mesh all the way around the wall and on the ceiling.
I would pour the floor and when that is dried I would form and pour the walls on a different pour, preferaby 8" minimum.
When the wall is dry I would use plywood and form a ceiling panel and brace it in which to pour an 8" ceiling on. I would have cattle panels and rebars across the ceiling welded to each of the vertical rebars to tie everything together. Put a couple small roof vents on each end, I used 4" PVC and works well. Don't forget to run electricity and an outlet inside.
