BitChin1
deleted double post
This is a very important issue to address!!!Eddie check into your annual ground temps for the depth you would install the pipe. What you want to avoid is any condensation forming in the pipe that might sit there for extended periods and allow mold to get going which will then be spread into your room when you turn it back on in late spring Google "earth tubes" to get more info on what folks use and potential issues and how to avoid them.
Insulated or not... If it condenses and doesn't vent enough to dry you are at risk.For road widening projects, I have torn down several buildings with hvac ducts in the ground. None were insulated or did I see any mold. But this is my limited experience in Ohio
I woke up this morning with the realization that I really don't want a basement, and I was overthinking this whole thing, making it a lot more complicated then I needed to. My reasoning for the basement was protection from tornadoes. Since I'm digging a hole in the ground, I might as well make it as big as the room that is going to be above it. There is no reason for a tornado shelter to be 16x16 feet. Once I got to thinking of how big it needed to be, and that while we where in it, we where going to be wide away and not doing anything until the threat had passed, I got to thinking that I could have everything i wanted by just building an above ground shelter in the corner of my garage. This now removes a huge weight off of my shoulders and allows me to move forward with what I really want to do, build my great room!!!
Thank you, I really do appreciate all the great advice and humoring me while trying to figure out how to build something that I now realize, I no longer want. If I would have just listened to my own words when I said that I never plan on going down there once it's built, I would have realized that I really don't have any need or desire to have a basement. As for storing stuff, I am already in the process of creating a canning/processing room that is 12x24 that will hold everything we plan to can or pickle.
Do you run the fan on the AC to help move the heat from the wood burner? If so, that would be enough air to stop the condensation and mold. If not a run once a week should keep it dry. I've never lived in a home that the heat moved that well without some help.
