Found one thing I don't like about Mahindra
   / Found one thing I don't like about Mahindra
After cleaning up the battery compartment and repainting damage caused by a leaking battery, I installed an OPTIMA Red Top.
Could up explain the damage that occurred from the battery leaking this is the point I was making thank you
Sent from my iPhone using TractorByNet
Could up explain the damage that occurred from the battery leaking this is the point I was making thank you Sent from my iPhone using TractorByNet
wow to early worked late last nite I was asking you to explain the damage that a leaking battery can cause to metal,wiring and rubber components this is exactly the point I was making thanks
   / Found one thing I don't like about Mahindra #15
I had no damage other than severe corrosion to the battery compartment area. I went through the process twice before buying the OPTIMA.
I must miss read your reply I thought you said repaired Damage and repainted area sorry I will be spending the money on a new battery to thanks again
   / Found one thing I don't like about Mahindra #17
Double check your charging voltage. If the voltage is too high the battery will "Boil" and leak acid. Charge voltage should be between 13.8 and 14.2 volts.
   / Found one thing I don't like about Mahindra #18
Second that. My battery is over 10 years old and so far is leak free and started the tractor every single time.
what would cause over charge I will check in am
   / Found one thing I don't like about Mahindra #20
Voltage greater than 14.2V will boil the battery. The best voltage is 14V when engine is reved up to about 2000 or more rpm. If the voltage is 14V and it is still boiling then the battery has bad cell.
RIT
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2121 (A51244)
2121 (A51244)
NEW Mini Excavator Fixed Thumb Attachment (A53002)
NEW Mini Excavator...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
EZ-GO D499 Electric Golf Cart (A51694)
EZ-GO D499...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
