pics of garden plows and 3 pt hitches
   / pics of garden plows and 3 pt hitches #1
weeder
Tuscola Illinois
John Deere 425 lawn tractor
Hey guys, I would like to see as many pics of garden plows with 3 pt hitches behind there garden tractors. Just curious of what I might need to look for in doing my 425.
Thanks weeder
   / pics of garden plows and 3 pt hitches #2
What do you call a "plow" ?? Anything that stirs up or turns over dirt?
Do you have the JD 3 pt hitch for the JD 425? That is what you will need, if I read your question correctly.
Yes I guess anything that will turn the sod over or stir up a pre tilled garden and yes I do have a 3 pt hitch but I don't know how things are hooked up to it. I hope this helps everyone.
Ok, just wondering I'll figure it out thanks
   / pics of garden plows and 3 pt hitches #5
Basically, there is a top arm for the top point connect, and two lower lift arms for the two lower points of contact.
Would you put up a pic of your 3 pt hitch, with it hooked to the tractor? Or is that dismantled at the time.
We're willing to help, if we can figure out what it is you need...
   / pics of garden plows and 3 pt hitches #6
It's not a plow, but this photo I found via Googling images of Category 0 3 point hitch shows the top and lower link setup for a scraper blade.
Steve
Well where do I find out the info on how to post a picture? I have tried to post pics on other sites but for some reason I am not very good at it. The hitch is off the tractor now but I do have a picture when it was on there. Just hoping I can figure out how to send a picture.
   / pics of garden plows and 3 pt hitches #8
   / pics of garden plows and 3 pt hitches #10
Here is a picture of the (cat 0) three point on my JD 330. I don't have a plow but this is my receiver that I use to move my log splitter, trailer, etc. I also have a 4' blade I use with it. Basically your top link is your biggest adjustment to control how aggressive you want the plow to cut into the ground.
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52128)
2012 Freightliner...
John Deere 693 Corn Head (A50514)
John Deere 693...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1CT2EFB75727 (A48836)
2014 Ford F-150...
H & S High Capacity Hayrake (A50515)
H & S High...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52128)
2014 Yale 3 stage...
