Rear retreaded Aircraft tires on a tractor?
   / Rear retreaded Aircraft tires on a tractor? #11
I have gone over this thread several times. I must have missed it but I am trying to find who sells r1 or r4 retreaded aircraft tires? I want them to fit 30 or 36 inch wheels.
   / Rear retreaded Aircraft tires on a tractor? #12
The second post above your post.
   / Rear retreaded Aircraft tires on a tractor? #13
Thanks but I went there and could not find rear tires. 30 or 36 in rims. What am I missing?
   / Rear retreaded Aircraft tires on a tractor? #14
I am only guessing, but surmise the resellers are cutting in a new tread pattern into the existing tire or retreading the aircraft tire to produce R1 or R4.
They glued a new R4 tread over the aircraft tire.
   / Rear retreaded Aircraft tires on a tractor? #16
The 46k and 50k load rating is probably a bit overrated in the application. They would only meet that rating at the appropriate pressure, which I doubt a homeowner ~100psi aircompressor can muster
You could max out the air compressor which on mine is about 140 psi and then use a nitrogen tank to top it off to the correct pressure. The cheaper option would be to use a scuba tank which I can get filled for free. Since it is a tractor less than 50 PSI is plenty. The biggest problem is the tractor axel is not rated to 96K.
   / Rear retreaded Aircraft tires on a tractor? #17
I have never heard of aircraft tires on a tractor, interesting.
   / Rear retreaded Aircraft tires on a tractor? #18
I remember several decades ago. A local farmer was planning to put aircraft tires on the front of a small tractor he got at a auction. The side wall were that hard that the local tire changer at the garage could not get them on as they had very little flex. Equipment is better now for changing tires.
It is common practice around here to have back tires mounted for traction in reverse on 2WD units with a loader.
Why spend the extra money if they work fine the way they are.
Al
   / Rear retreaded Aircraft tires on a tractor? #19
I have a Ford 4000 with aircraft tires on front. But recapped tire have been used by operators on industrial equipment for a while. I have put them on hoes and motor graders. I would use them on my tractor and smile.Image no thorns penetrating the carcass of a tire.
   / Rear retreaded Aircraft tires on a tractor? #20
The wheels on even a B747 or A380 aren't that big. That's why you can't find them.
747 wheel with people for reference
You can go here and find the sizes for just about any aircraft: https://www.goodyearaviation.com/tires/tire-lines.html#section2
And finally, here it is straight from Boeing: http://www.boeing.com/assets/pdf/commercial/airports/faqs/aircrafttiredims.pdf
The 747-400 uses the same tire as the 777 in the above example.
HEAVY DUTY STORAGE RACKS (A54757)
HEAVY DUTY STORAGE...
2003 Big Tex 10PI...
2015 Chevrolet Malibu Sedan (A55853)
2015 Chevrolet...
2013 ISUZU NPR STAKE BODY TRUCK (A56138)
2013 ISUZU NPR...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
Portable Restroom (A54865)
Portable Restroom...
