Free your metal! PB B'laster & WD40
   / Free your metal! PB B'laster & WD40 #11
I keep a can or two of pb blaster around at all time. It will free up about anything,but for those things it dont work on, I have used the acetone/atf mix for years. If its really stuck, the acetone/atf will work better and anything. Works great at freeing up stuck engine, just fill the bores and let it set for a day or three and try giving it a spin. Motor will smoke like crazy when she fires up, but it keeps the Knats away.
   / Free your metal! PB B'laster & WD40 #12
We used to use straight ATF in old John Deere 2 cylinder tractors to free them up. Also some of the old wrenches such as my dad used to use a mix of diesel and old engine oil. Don't fool with them old irons any more. I am a big fan of PB Blaster, they also make some good contact cleaner I like. I buy it and WD-40 in gallon cans. The first of PB I bought at Oreilys auto parts came with a metal spray bottle. LUTT
   / Free your metal! PB B'laster & WD40 #13
I can spray PB Blaster outside at arms reach with the wind blowing sideways, wait 3 hours and go in for lunch and my wife will complain of a huge head ache. I finely threw the can away. I will have to try that homemade mix. Thanks Ed
Is it the smell? ?
   / Free your metal! PB B'laster & WD40 #14
We use pb or wd40 but prefer pb blaster for our high jackers. They have 2 shafts that slide together and if left in the rain or forced together without lube are a b***** you get part and for the winch and wheels on the forks
Also more technical name "duct lifts"
   / Free your metal! PB B'laster & WD40 #15
Problem with acetone is that it can damage a lot of paints, finishes, and plastics, so I am very careful when I use it, even on a rag. I'd be *super* careful putting it in a spray bottle even if mixed 50/50 with transmission fluid.
   / Free your metal! PB B'laster & WD40 #16
Acetone is the same thing as finger nail polish remover, so yea, its hard on paint. I have use Denatured Alcohol in the place of acetone, results seem similar.
   / Free your metal! PB B'laster & WD40 #17
Is it the smell? ?
I don't know really. She has a nose that can smell things most can't but she gets a head ace even when she can;t smell the PB. She does have some allergies so that may be it. What ever it is it's not worth it for me to have it around. Ed
   / Free your metal! PB B'laster & WD40 #18
Because a firm believer in the early 80s while working on workover land rigs. We went to a location that had an old sucker rod oil well, the 12" casing cap was locked up tight, we beat it with a 12lb sledge and bent the handle on a 60 inch chain tong using a hydraulic ram to pull on it. That afternoon we just soaked it down with a few cans of WD-40, next morning we put the chain tong back on it and it unscrewed with one person, blew my mind WD-40 would work that well.
   / Free your metal! PB B'laster & WD40 #19
Had you used Fluid Film on it, you would have found it had unscrewed itself by next morning. ;-)
Sent from my iPad using TractorByNet
   / Free your metal! PB B'laster & WD40 #20
I use PB because it works, in aerosol cans since I don't gon't go through it fast enough to justify buying the stuff in bulk cans...and I can find it anywhere. I use WD-40 because I can't stop people from giving me cans, haven't actually bought any in decades. But my favorite commercial product is Kroil, from Penetrating-Lubricating Oils . I've got one little bottle which I hoard for the real hard cases.
My brother works on more stuff than me and is a big fan of the get-it-hot, hit it with any spray, tap it with a hammer, then turn approach, and I have seen it work wonders (20 year old muffler bolts on an Allis Chalmers).
I've known about ATF-Acteone and the related "Ed's Red" for a while, but haven't used them, I may make some up to play with one of these days.
Toyota 6FGU25 Forklift  5,000 lb Capacity (A53472)
Toyota 6FGU25...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A53472)
2018 Link-Belt LBX...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
