Timberline 25 shingles going bad
   / Timberline 25 shingles going bad #11
Did you contact the manufacturer? Is it GAF? Is the roofing company still around the installed them?
I don't know that particular shingle, but find it hard to believe that the shingles are failing due to age at only 20 years. Roofs are very simple, but if you cut one corner, things go bad quickly.
Do you have trees over your roof that have been dropping branches on the roof? It's very hard to find a hole caused by a branch since they hit, create the damage, then bounce or slide down the roof.
Was this new construction or where the shingles installed over existing shingles? existing paper? When the roof was installed, was the existing roof completely removed and the decking inspected? I'm in attics all the time and it's shocking to see what the decking is like in some homes. In places, there is no decking and the shingles are nailed to the felt paper with nothing else holding them in place!!!!
Leaks in roofs are most common around vents or other things going through the roof. Reusing old vents, or not sealing around them happens all the time. Skylights are horrible in so many ways, especially for leaking!!!!
How where the valleys done? Did they use metal flashing? Grace weathershield? Or just overlapped felt paper?
Leaves building up in a valley will lead to leaks in the valley. Same thing with leaves in the gutters. Water overflows the gutters and then gets into the soffits. Sometimes the water travels quite a distance before you see it. In fact, most leaks that you see in the house are not under where the actual leak i n the roof.
Pictures of the shingles would really help.
   / Timberline 25 shingles going bad #12
I would guess if the roof is leaking it's because when the shingles were installed they never left enough side lap between one row of shingles and the next in places. I've seen this with the shake look shingles being installed because it's not that obvious by just looking at the roof. The minimum distance from the edge of one row of shingles to the next is right on the packaging generally 5.5" and I've seen them installed with 1.5" which will develop leaks.
   / Timberline 25 shingles going bad #14
insufficient attic ventilation absolutely kills roofing shingles........go up in the attic on a nice summer day and that temp is what the shingles are feeling as well as the suns rays.......ridge vents don't work without adequate unblocked soffit vents to go with it....can't tell you how many times I've seen the insulation pushed up tight to the roof edge in the attic completely blocking the airflow........and roof hawks are worthless......best is continuous soffit vents and powered attic ventilation fans on a thermostat set.........keep the attic temp low and get a longer life out of the shingles.......plus your house stays cooler.........Jack
   / Timberline 25 shingles going bad #15
A common misunderstanding is that venting an attic is to try and cool it off. The actual reason for venting is to keep the lumber and decking dry. Heat rises. Air entering the attic from the soffits is lower then where it leaves the attic at it's peak. Ridge vents are the best because they are at the highest point in the roof, but turbines and gable vents do the same thing. It's all about the air heating up in the attic so it moves from low to high. The airflow dries out the moisture that would accumulate there from condensation in the mornings.
Not having air flow will cause mold and rot in the wood. I've heard that it affects shingles, but I've never seen this myself. I'm not aware of moisture under a roof being the source of shingle failure. The paper under the shingles keeps whatever is happening in the attic separate from what's happening outside the roof.
   / Timberline 25 shingles going bad #16
I put steel on all of my buildings. The price was a bit more but goes on a lot quicker. When the cost is calculated in to replace the roof in 20 years the steel makes a lot more sense to me. I also am able to do steel by myself.
I did the same when I re-roofed my garage last summer. Materials cost was about the same, and the job went a lot faster. I just nailed strapping over the 40 year old shingles that were there...lotta time saved in not having to strip the roof, which would have been necessary with new shingles. I don't see why pro roofers charge a 50% premium for steel roofs when what little additional material cost is more than outweighed by less labor.
Snow slides right off now, saving me having to get up there and shovel/roof rake it several times each winter.
Thanks for the reply Eddie. I have not contacted the manufacturer, it is GAF. There are trees nearby but none overhanging the roof. This was new construction, I used ice and water shield up 6 ft. felt, then shingles. A full ridge vent and eave vents, which I know are not plugged as I used baffles and blew in the insulation myself. There is only one valley, it has aluminum flashing, 90 lb. roll roofing, and the shingles were "basket weaved". No leaves in the valley, and no gutters, no leaks anywhere near the valley. Billrog: When I ran into a situation where there would be an unacceptable side lap, I would cut the previous shingle back [ before I nailed it to the roof] so that side lap would be sufficient. Square 1: Can you tell me more about the lawsuit? This is the third house I've built,and many reroofs for other people. I have been in construction most of my life. I didn't cut any corners. I thought I was buying top of the line shingles and disappointed. I am seriously considering going with steel as more and more homes in the area are using steel. These Mich. winters are brutal. My brother in law builds pole barns and knows his way around steel roofs, so I will probably go that way. Thanks for all your help guys, Bill
   / Timberline 25 shingles going bad #18
This is my understanding in talking to various contractors. They had a few years of bad shingles about the same vintage yours were installed. I had a garage built, about 1998 as I recall. The houses on the house were probably 7 years older. The shingles on the garage failed much sooner, they lasted about 12 years. As mentioned above, enough roof vents is important. I probably had enough vents, but not enough to meet the warrant requirements. Like so many warranties, its really often tough to collect.
   / Timberline 25 shingles going bad #19
I'm old enough to remember when a bundle of shingles were about 50% thicker than they are now. They don't make them like they used to. We put Timberline on both houses here on the farm about 3 years ago, one has a 12/12 pitch, the other a 4/12 so if I live long enough I'll see which one last longer.
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
DOWNING MANUFACTURING BITUMINOUS APPLICATOR (A51406)
DOWNING...
2023 KOMATSU PC55MR-5 EXCAVATOR (A52705)
2023 KOMATSU...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
ASCO Transfer Switch (A52377)
ASCO Transfer...
