EddieWalker
Epic Contributor
Did you contact the manufacturer? Is it GAF? Is the roofing company still around the installed them?
I don't know that particular shingle, but find it hard to believe that the shingles are failing due to age at only 20 years. Roofs are very simple, but if you cut one corner, things go bad quickly.
Do you have trees over your roof that have been dropping branches on the roof? It's very hard to find a hole caused by a branch since they hit, create the damage, then bounce or slide down the roof.
Was this new construction or where the shingles installed over existing shingles? existing paper? When the roof was installed, was the existing roof completely removed and the decking inspected? I'm in attics all the time and it's shocking to see what the decking is like in some homes. In places, there is no decking and the shingles are nailed to the felt paper with nothing else holding them in place!!!!
Leaks in roofs are most common around vents or other things going through the roof. Reusing old vents, or not sealing around them happens all the time. Skylights are horrible in so many ways, especially for leaking!!!!
How where the valleys done? Did they use metal flashing? Grace weathershield? Or just overlapped felt paper?
Leaves building up in a valley will lead to leaks in the valley. Same thing with leaves in the gutters. Water overflows the gutters and then gets into the soffits. Sometimes the water travels quite a distance before you see it. In fact, most leaks that you see in the house are not under where the actual leak i n the roof.
Pictures of the shingles would really help.
