Charge your equipment batteries and they last a lot longer
   / Charge your equipment batteries and they last a lot longer #11
I built a custom set of jumper cables about 35 years ago that are worth mentioning. Used heavy duty nickel clamps and 20' of 3/0 welding lead for each cable. These jumpers are still in excellent condition and have been used for the most part to start other peoples vehicles.
Wow 3/0 welding cables for jumpers is quite a bit of overkill, even 2/0 is much more than needed. I bet they are a bear to handle due to weight and stiffness.
The best jumpers I ever had (prior to them being stolen) was a set I made from Postweld Heat Treating cables. These were 1/0 cables with a really flexible wire and insulation, much more flexible than regular welding cable. I put the heaviest clamps on them that were available and made them 30 feet long. This was long enough so that I could pull up behind a car and jump them rather than getting nose to nose. I sure wish I had those today.[/QUOTE]
Well 3/0 is larger than needed but it was a drop left over on the roll when I rewired a few welding machines. Flexibility is good with the high strand count wire. I bought the nickel clamps and then had a good set of jumpers for my old D7. The total cost was about the same as a 12' set of cheaper cables with #4 wire. Plus the heavy cables are still good today.
   / Charge your equipment batteries and they last a lot longer #12
Batteries loose longevity when their charge state drops below 80%.
Battery Tender Plus - 12v - Herrington Catalog
This type of tender will bring a battery back to full capacity, while not overcharging it. Trickle chargers can damage a battery by overcharging, boiling off the water, etc. in lead acid batteries. Life of the battery can and likely will be extended by using a tender, BUT one either pays to replace chronically discharged batteries, or pays for the electric usage of the tender to maintain them.:confused3:
Granted, maintaining them may be less hassle overall than removing, exchanging and buying a replacement every couple of years or more.
   / Charge your equipment batteries and they last a lot longer #13
For: Coyote Machine:
Don't know for sure, but I would expect that the"electric usage" of my 14
Battery Tenders" is less than $2 per month, and that is a VERY SMALL price for maintaining 14 batteries.
Maybe $24 per year total.
v/s $100+ for replacing just ONE battery each year.
That puts me $76 to the good every year, and that is assuming only ONE battery would die.
Could easily be more than one, if not using battery maintainers.
   / Charge your equipment batteries and they last a lot longer #14
I got 11 years out of my original tractor battery, 10 years from original car battery . My current pickup battery is 10 years old and still going strong.
My 2007 dual sport motorcycle and 2009 street bike still running original batteries
None have ever had a maintainer on them.
   / Charge your equipment batteries and they last a lot longer #15
Rut Ro you might have just put the kibosh on you. Spit and turn around 3 times.
   / Charge your equipment batteries and they last a lot longer #16
Maybe just because of dumb luck, I have had no problems with my tractor batteries. I do use a cheap HF battery tender, and I installed a 12V ciggie lighter outlet to make it easy to plug a tender in, and unplug it when the tractor is used.
   / Charge your equipment batteries and they last a lot longer #17
For fried:
At on average $56 per tender x 14 batteries =$784 in tenders alone. Some savings.:rolleyes:
   / Charge your equipment batteries and they last a lot longer #18
My little BX battery is going for my personal best record... 12 years.
Really don't do anything special except it lives in a shed and temp extremes are not typical in the SF Bay Area.
   / Charge your equipment batteries and they last a lot longer #19
I keep battery maintainers on everything. I prefer the Noco genius maintainers.
   / Charge your equipment batteries and they last a lot longer #20
That's exactly what I did. Except I added a switch on my dash for the outlet. I used that to run a sprayer last summer, just shut it off with a flick of the switch.
Land Pride RCF2072 (A50123)
Land Pride RCF2072...
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
KOBALT TRUCK BED TOOLBOX (A51248)
KOBALT TRUCK BED...
2015 DODGE RAM 4500 HD SERVICE TRUC (A51247)
2015 DODGE RAM...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
10' WROUGHT IRON SITE FENCE (A51248)
10' WROUGHT IRON...
