220V electricity and 110V
   / 220V electricity and 110V #11
Consider using a water powered softener (Mine is a Kinetico).
   / 220V electricity and 110V #12
Maybe I'm missing something, but How do you intend to protect the wire after you come off 1 leg of the 220 ?
   / 220V electricity and 110V #13
I'm guessing with whatever is protecting his 27.5 amp (??) circuit.
What is a 27.5smp circuit?
Is this circuit from a generator?
yes. It goes through a manual transfer switch then on to the fuse panel that is for the well pump. I didn't want to mention the transfer switch and genny because I figured like in other threads about gennys there would be a hot 'n' heavy discussion about the virtues of using a genny and mains hydro a the same time and back feeding and all that. There will be NO backfeeding as the transfer switch is there.
The circuit for the light and watersoftener will be off a 2 circuit fuse box which will be off one leg of the transfer switch on the genny side ONLY. And I only intend to use 1 fuse and stick another one in the other hole just to plug the hole and act as a spare. Those fuses will be 15 amp fuses. The wiring will be 14/2 indoor wiring.
   / 220V electricity and 110V #16
What kind of LED lamp draws 4 amps - 480 watts at 120 v? Really a lot of light!
Man, I want one of those. It should really light up the shop.
   / 220V electricity and 110V #17
The pressure switch is in the water line beside the pressure tank in the house. The pump is down hole in the drilled well.
The water softener is down stream from the tank and pressure switch.....The water softener has its' own transformer that plugs into 110V (24V 2.1A)
,,,:confused2:,,,You cannot draw power "down stream" from the pressure switch unless the pressure switch is closed - running the pump.
... And if that transformer puts out 2.1A at 24V it only draws ~ 0.5A from the 110V line.
   / 220V electricity and 110V #19
first off, I am no professional and my advice may be only worth nothing. But.... Typical 220V applications such as pumps and table saws etc are only using three wires. The black leg, the red leg and the ground. The white, neutral, is used to make a 120V circuit with one of the hot legs. This is typically seen in stoves and dryers. They have fours wires including ground. The elements are running 220 volts and all the controls are 120 volt. Think of the neutral wire as 0. The red wire as 120 and the black wire as negative 120. Either the red or black connected to the white is 120 volts difference. The red to the black are 240 volts apart
Basically since you have red white and black it is doable. Probably the simplest way would be to install a sub-panel on the wire. The sub panel will have four spots to connect, one for the ground, one for each hot leg and one for the neutral. You will then be able to put In 120V and 220V breakers. Since this will maybe be off of a generator you should try and balance the load, the 240V pump is pulling equally off of each leg. You then should have your softener connected to one leg and your light to the other. If at all unsure please consult with an electrician, as I would hate for anybody to get hurt from misinterpreting advice they read online.....
I am going to draw the power from the dedicated fuse box for the pump. Having rethunk it.
2025 CFG Industrial QK16R (A50123)
2025 CFG...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2025 CFG Industrial KKT(A)27 (A50123)
2025 CFG...
2016 FREIGHTLINER CASCADIA DAY CAB (A53426)
2016 FREIGHTLINER...
Wolverine 72" Hydraulic Skid Steer Tiller, New  (A52384)
Wolverine 72"...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
