Frigidare icemaker making thumping noise
   / Frigidare icemaker making thumping noise
Sounds like it is coming from the left side in the wall of the fridge
   / Frigidare icemaker making thumping noise #3
I've replaced several ice makers. It's easy and I get them locally for around 60 bucks.
Don't waste too much time trying to fix it.
I turned the ice maker off and it still made the noise. Now a few hours later and the noise is gone. We'll see if it returns.
   / Frigidare icemaker making thumping noise #5
The ice maker in my previous fridge made a very similar noise. Its was the unit cycling between make ice & done making ice. The "wand" that determines how much ice was in the storage tray had slipped a cog and was causing the unit to cycle. I moved the cog end up a notch and it then worked fine. That was until I opened the fridge one day and the "magic wand" was haywire again and the ice maker was well on its way to filling the entire fridge with ice cubes.
BTW - after 28 years the old fridge finally gave up. My new unit DOES NOT have an auto ice maker.
   / Frigidare icemaker making thumping noise #6
Wonder if something happened to cause an "iceberg" over the cutting wires and the feeding mechanism was playing "I think I can...". My mother in law had that happen on her new fridge because she shut the icemaker off mid-cycle (she watches pennies...sometimes I shake my head). We did a manual defrost and everything returned to normal. I told to leave it alone from now on.
   / Frigidare icemaker making thumping noise #7
One year old fridge, icemaker suddenly started making this noise tonite. Before I go tearing into it deeper any ideas of what it might be??
https://youtu.be/rlqhdcMoSIA
Yep. The heater that causes the cubes to release and fall isn't working. When they make that thumping noise its time to replace them.
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A52748)
2022 NEW HOLLAND...
Caterpillar Loader Quick Coupler (A52748)
Caterpillar Loader...
2022 McConnel TRAXX RC28 Remote Controlled Slope Mower (A51691)
2022 McConnel...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
