New GC1715 - Its fine . . . and its mine.
   / New GC1715 - Its fine . . . and its mine.
Scut 4, that Fiziks is fast on the video. Lol
You're actually seeing my tractor with the prototype quick attach designed for the dl95 loader. If you look carefully . . you'll also notice it has a 2" receiver hitch built in. It means you can mount a trailer hitch ball or hook a receiver mounted winch or etc. etc..
It also means if you need to cut grass and don't want all the fel weight . . you can drop the 155# bucket in less than a minute.
   / New GC1715 - Its fine . . . and its mine. #35
Looks like a great addition to the GC1715. Might be signing papers tomorrow morning for my new machine.
How about an attachment to the bucket with teeth?
I used to own a case skid steer. Trying to dig an area with sod with a straight bucket wasn't easy. I need teeth, bro!
   / New GC1715 - Its fine . . . and its mine. #36
Massey offers a factory tooth bar, but you may also want to look into a piranha tooth bar from Bxpanded.
   / New GC1715 - Its fine . . . and its mine. #37
Thanks Fizik. Those piranhas look they'd getter done!
   / New GC1715 - Its fine . . . and its mine. #38
I should mention that I have the Massey factory tooth bar, which is more traditional design with several longer teeth. This has its advantages...they make a nice "rake" on the bucket edge, and also are easy to hang straps or chains over when lifting things. However, I managed to break one tooth off and bent a couple others. It also attaches with 4 bolts through the bottom of the bucket. Next time around, I think I'll go with a piranha!
   / New GC1715 - Its fine . . . and its mine. #39
My plan is the same get a BXpanded Piranha toothbar for the FEL and their Talon Ripper Tooth for the backhoe to work on some of the roots and stumps on my property. Seems like both BXpanded and Bro-tek make some quality items for these SCUT's.
   / New GC1715 - Its fine . . . and its mine. #40
I have the Ratchet Rake and use it a lot in the spring to clean ditches of wet leaves and to rake out rough areas.
1998 John Deere 544H Articulated Wheel Loader (A50322)
1998 John Deere...
MAHINDRA 48" (4') ROTARY TILLER (A51243)
MAHINDRA 48" (4')...
2017 LEEBOY 8520 ASPHALT PAVER (A51242)
2017 LEEBOY 8520...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2017 BOMAG BW145D SMOOTH DRUM ROLLER (A51242)
2017 BOMAG BW145D...
4' DISC HARROW (A51243)
4' DISC HARROW...
