95 ford f250 wont charge battery
   / 95 ford f250 wont charge battery #1
echoman
Member
wv
kubota b2920
This is my fathers old farm truck that we use on the farm and to move equipment. I took the alternator to autozone and had it tested. They said it was not charging,which did not surprize me. It was the original alternator . I replaced it with a rebuit one ,but it still didnt charge. I took it back and had it tested ,but they said it was ok. I checked all the fuzes ,they were all good. I read that it could be the fuseable link ,but were is it and how do you test it? I'm stumped at this point.
   / 95 ford f250 wont charge battery #2
I dealt with the same thing on a F350 of a boating buddies. I can't remember precisely but it was in a wiring harness along the firewall from what I remember.
Chris
   / 95 ford f250 wont charge battery #4
Was the battery checked?
That's what I was wondering as well.
Also, are those internally regulated or externally? I can't remember.
thanks for the replies.Yes I did have the battery checked and its ok . I'll look around the firewall I'm not sure what one looks like. I've never ran into this problem before. I might have to tke it to a shop ,I prefer to fix things myself . thanks again
   / 95 ford f250 wont charge battery #6
These models also have an external voltage regulator. Take that in and have it checked too.
its regulated internally , its on the side of the alternator . thanks
I didnt know it also had an external regulator . I'm learning alot
   / 95 ford f250 wont charge battery #9
is the voltmeter saying low? the battery light on? have you actually put a meter on the battery while running to see what the output is?
yes the voltmeter in the truck is saying about 9 volts . I checked it with a meter. Fully carged battey said 12.36volts put it in the truck and started it checked the battery while it was running 12.16 voits at battery and at alternator . the longer it runs the lower the volts go. shut it off and it wont start until I recharge the battery thanks for the replies
JOHN DEERE 6615 TRACTOR (A51406)
JOHN DEERE 6615...
2012 Ford F-350 Reading Service Truck (A51692)
2012 Ford F-350...
Peterbilt (A51692)
Peterbilt (A51692)
2013 F-550 Bucket Truck (A53473)
2013 F-550 Bucket...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
2016 Isuzu NPR Cab and Chassis Truck (A51692)
2016 Isuzu NPR Cab...
