SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,325
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Here is a link to the technical data sheet.
Cure time is a max of 24 hours but if faster cure is desired then an activator product can be applied to the parts first.
http://tds.henkel.com/tds5/docs/620-EN.PDF
I would take the time to clean all rust and crud off the parts before using.
If not using the activator I would wrap electrical tape around both ends of the parts to keep air out since the curing is anerobic.
It can deal with up to a 15 thousand of an inch gap ie. .015 which is a pretty sloppy fit!
I doubt the shaft is hardened but agree grinding or filing a flat spot for the set screw to bear against would be prudent.
Dave M7040
NJDiverDan to me it would be worth the chance on using the Locktite that Dave M7040 has provided information on. It's a little pricey and I don't mind helping other people spend their money.so give it a try and let us know
. Some people get a chuckle when you mention stuff like JB Weld for repairs but I believe all farm repair shops need a room full of JB Weld...Locktite...Gorilla Glue...Duct Tape. Enjoyed reading everybody's idea and I've tried most of them.
Well I am debating on the loc-tite vs drilling a cross bolt. I like the idea of being able to remove the yoke easily but in realality I have never removed the implement side of any of my PTO shafts.
Going to get some on order tomorrow.
I would not use this and count on getting it off with heat that doesnt compromise seals and bearings. #620 is strong up to 450F, and heat up to around 250 actually strengthens it. You would be better off with Loctite 635 or 638. ... Equally strong but they soften up in the 200 to 300 F range, and your shaft will never get above 120 or so unless you run out of oil. -- Also, avoid any accelerant other than moderate heat. Chemical accelerants usually weaken the product.Know what you mean about trying to decide. One thing it is removable, any propane tank will easily heat it up to temp's necessary for removing it and won't hurt the shaft or the collar. You could protect the seal in the gear box from excess heat while removing but chances are the reason for removing the collar would be to repair the gearbox. . . and you would replace the seal anyway. I'm also going to add the locktite to my arsenal of repair junk. Good luck let us know how it holds up. I'm assuming from your location you'll have the chance to try it out soon.
larry
