BX25D / B2601 Time to switch between MMM to BH w/ subframe
   / BX25D / B2601 Time to switch between MMM to BH w/ subframe #11
I should probably not comment here because I don't have a MMM but I do have a BX25 with a hoe. I believe the MMM uses the 3-point hitch hydraulics - mower up, 3-pt up. And the hoe uses the 3-pt hydraulics plumbing so while both the BH and MMM can be on the machine at the same time, I think only one will work depending on how the plumbing is connected, which takes maybe a minute to change.
Anyway, you will love your new BX.
   / BX25D / B2601 Time to switch between MMM to BH w/ subframe #12
It's seperate plumbing on the 25D.
Don't know how you could use the 3point hydrolicis to run the BH as you wouldn't have any flow unless you cross something over infront of the valve...but that's pre cup of coffee thinking.
OP congrats, you will love it. I moved up to an MX but kept the BX and glad I did, spent more time in the BX seat than the MX over the last five or so days. Post us some pics and list the accessories you got:thumbsup:
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2014 FORD E-350 11 PASSENGER VAN (A52472)
2014 FORD E-350 11...
2005 Nissan Frontier 4x4 Pickup Truck, VIN # 1N6AD07W35C433334 (A51572)
2005 Nissan...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A52748)
FIRESTONE 9.5L-15...
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
